Is it just the diamond version is just an old design?
Most of them were replaced by the Brecknell Willis high speed design, which I believe was mandatory for 110mph operation on the WCML so replaced the original type on Class 87 (a sort of diamond but the lower struts crossed over) and found its way onto various other locos and units too. This is a single-arm design.Many British electric trains had the 'diamond' type when new in, ooh, 19-'long time ago'.
The trains that were converted from 1500VDC to 25kVac (and 6.25kVac) were fitted with Stone-Faiveley AMBR single arm pantographs. These pantographs are heavy and complex with their upwards force being provided by mechanical springing. Although some of their contemporary EMUs and locos that were ac from introduction, were also fitted with the Stone-Faiveley type and could run at service speeds up to 100mph (mainly EMU class 309 and loco classes 80-86), they have now been retired. The other MKI EMUs (classes 300-305 & 308,) were 75mph designs. Later classes of MKII classes (310, 311, and 312), 'PEP' derivatives (classes 313-315) and some MKIII EMUs (classes 317-322) were fitted with AMBRs but where the trains were expected to run a large part of their diagrams at higher speeds (90-100mph) under modern lightweight auto tensioned OLE, the Brecknell-Willis with it's pneumatic suspension, secondary suspension and better aerodynamics has been the preferred type. This design has been developed for speeds up to 140mph when suitably tuned with adjustable aerofoils.Most of them were replaced by the Brecknell Willis high speed design, which I believe was mandatory for 110mph operation on the WCML so replaced the original type on Class 87 (a sort of diamond but the lower struts crossed over) and found its way onto various other locos and units too. This is a single-arm design.
There was an experimental cross-arm design developed by GEC-AEI that was used on some class 86 & 87 locos, but those fitted were replaced with Brecknell-Willlis types after a while.
Diamond pantographs seem to be used on trains running on DC networks at speeds less than 200km/h (124mph) . Maybe there is something inherent in that design that suits DC operation. Or the operators sticking to a tried and tested product?
I wonder if the pantographs are a reason for the seemingly random restriction of some 87s to 100mph even in 1986, two years after 110mph operation on the WCML commenced.
It was because they had not been equipped for one-man operation if I remember right. 87008/010 & 019 were the last to be equipped.
110mph operation on the West Coast required Brecknell Willis high-speed pantograph fitted locos. The 87s were progressively modified for the 110mph launch in 1984 - and it did take a while to do them. Anything not Brecknell Willis fitted was 100mph restricted.It was because they had not been equipped for one-man operation if I remember right. 87008/010 & 019 were the last to be equipped.
The 87s all had BW pantos by 1986 though and were all 110mph capable. BR abandoned 110mph running in effect in early 1986 as it was costing around £500,000 a year in manning & extra maintenance costs.
It was progressively reintroduced after single manning mods and union approval. HSTs north of Newcastle were restricted to 100mph so they could be single manned around the same time (again for cost reasons). Unions doing what unions do best!
The original ETR500 power cars - now reclassified as E414 locos and marshalled each end of a rake of UIC loco hauled stock still have diamond pantographs fitted. So do ETR460/463/485 Pendolinos.Italy had diamond pantos up to the 1990s including the ETR 500 HST's
Not too much knowledge of Italian loco classes, but the majority I saw this last week, passing while we were on the beach at Taormina, Sicily, seemed to have diamond pan's.The original ETR500 power cars - now reclassified as E414 locos and marshalled each end of a rake of UIC loco hauled stock still have diamond pantographs fitted. So do ETR460/463/485 Pendolinos.
Well of course, they had AWS. But then someone decided (without risk assessment) they could run without AWS, if it had failed. Someone else decided (also without risk assessment) they could run single manned, without thinking of the AWS failure possibility in combination. Someone else (no you-know-what) put up OHLE on the GW main which ended the old ability on this exceptionally straight line of always being able to see one or two signals ahead. The civils chimed in putting in single lead ladders without the previous double-crossover ability to set the flanking crossover move as protection, which had hitherto always been interlocked (guess what they didn't do). And finally someone different again decided (still no risk assessment) that the old priority given to expresses was no longer relevant in privatisation, so it could readily be pulled up to allow a freight to cross in front of it. Then there was Southall....It was progressively reintroduced after single manning mods and union approval. HSTs north of Newcastle were restricted to 100mph so they could be single manned around the same time (again for cost reasons). Unions doing what unions do best!
Pretty much universally Brecknell Willis isn't it?Incidentally. Who supplies the pans now fitted to new units & those on the 350’s?
Here in the Netherlands (1500 V DC everywhere*), you'll only find diamond pantographs on heritage rolling stock. The fleets used for squadron service all have Z-shaped pantos.Diamond pantographs seem to be used on trains running on DC networks at speeds less than 200km/h (124mph) . Maybe there is something inherent in that design that suits DC operation. Or the operators sticking to a tried and tested product?
I did read in one of my books that diamond pantos are more suited to DC use. Something to do with the high currents and heavier OHLE.
Edit- Found the book there. Its is to do with the OHLE. Diamond pantos are useless under tensioned, variable height OHLE. They are slow to react to changes in wire height or wire bounce so the carbon strips get damaged easily from the wire smashing into them.
