Tail Lights & Locomotive Head-Codes
The Liverpool & Manchester railway introduced a rule that every train must have a light on the rear so the lineside staff could see that no wagons had been left behind in the section, and also (hopefully) to avoid rear-end collisions on the line. Originally these lights were red when moving and blue when stationary. The brake vans attached to trains from the 1850's on carried lights mounted both on the rear and also on the sides. Both these lights showed red to the rear and some of the side lights showed white to the front. When the brake vans disappeared in the 1970's and 1980's a single tail lamp was attached to the rear of the last vehicle in the train. These lights were still the standard white oil lamps with a red lens, electric lights, again with a red lens, appeared in the 1970's and a yellow, flashing, electric rear lamp was introduced in the mid 1980's.
Head codes were shown on the front of the locomotive itself. These appeared in about 1850 and originally consisted of a number of white painted oil lamps which were mounted on brackets fitted to the buffer beam and boiler door of the loco. These codes showed the type of train, express or slow, goods or passenger, and were introduced to help the signal man when the line was being operated on the 'interval' system (described below). The lamps were carried on a set of four brackets fitted to the locomotive buffer beam and boiler door. Most codes required only two lamps to be fitted.
Fig ___ Original RCH Code for Locomotive Lamps
The Railway companies had their own variations on this arrangement, Southern Railway and cross-London trains were fitted with two additional positions on either side of the smoke box door on the front of the boiler to give a total of six positions. Other variations were plain white disks used in place of the oil lamps for day-time working (used by the Southern Railway and London & North Eastern Railway) whilst some companies had numbers or different shapes or colours in place of the white disks. At least one company used a set of small 'semaphore' type signals mounted on the front of the boiler.
At about the time of the 1923 grouping, a new code was evolved, again with four brackets as before but which only required a maximum of two oil lamps.
Fig ___ RCH revised lamp codes
The Southern Railway continued to use its own system of five positions and the old Glasgow & South Western and Caledonian lines under LMS ownership did not conform to these national codes for internal working.
Route Indicating Head Codes
The simple indication of train type, although useful for the interval signalling system, was not ideal for traffic reporting purposes. Some lines found it preferable to add an alpha numeric code indicating the service the train was on (i.e. 'this is the 8.15 London to Manchester service'). The Southern Railway and Great Western Railway added their own two character (SR) and three character (GWR) alpha numeric head codes, displayed on metal plates fitted to the front of the locomotive.
British Railways diesel locomotives built before 1961 for the Southern and Western regions of British Railways were often fitted with two and three character headcode boxes to display the special codes used on these lines (inherited from the SR & GWR). The Southern Region Class 33 (as available from Graham Farish) for example displayed the code on a simple roller-blind in the centre cab 'window' and the Western Region 'Warships' (available from Minitrix) originally had a three-character code box built into the nose.
Fig ___ Southern Region and Western Region Codes
British Railways used the RCH standard lamp codes and adopted the disks for all locomotives except Diesel Multiple Unit stock. On diesels the lights were electric and were built-in to the ends of the locomotive body, the discs were permanently fitted but could be folded in half (the inside face was white, the 'rear' face of the fold-down upper half was the same colour as the locomotive). The centre two discs were off-set slightly to the right (that is to your left when looking at the front of the locomotive). The two additional lights on either side of the smoke box door were included and on Southern region diesels the two additional positions were fitted with standard British Railways fold down disks. On the DMU's there were two lights fitted low down to either side of the front of the vehicle (rather like headlights on a road vehicle but not as bright), these replicated the passenger train oil-lamp headcode. On the DMU's the lights showed white to the front and red to the rear.
In 1960 the disk system was officially replaced by four-character head-code boxes which displayed the actual diagrammed reference for a particular service. On steam locomotives these four character head codes were displayed using metal plates painted black with code letters and numbers about nine inches to a foot high in white. Diesel locomotives displayed the code in an illuminated box on the locomotive front. As noted above the code displayed was related to the specific diagram the train was working and was intended to assist signalmen in reporting train movements.
