Why is LHCS unfavourable nowadays?
BuryBlue
8 Jun 2016
The title is self explanatory. Why are new D/EMUs favoured so strongly over a loco set? Surely it can't just be the acceleration advantage. Considering the shortage of (especially) diesel traction in various regions, I'm surprised there isn't more demand for the spared HSTs/225s, or indeed new locomotives and repurposed Mk3 carriages.
I'd also think they'd be cheaper than a multiple unit set as well. Is it to do with efficiency perhaps?
Philip Phlopp
31 May 2015
Reliability and track access charges.
Lose an engine on a LHCS set, and it's sat, dead, waiting for assistance, lose an engine on an HST set, and it'll do 100mph at a push, allowing some recovery of service. Lose an engine on a DMU and it'll be anything from a minor inconvenience to a bit of a problem.
EMU stock, particularly the new generation, have duplicate systems - two or three transformers, two pantographs, and form half sets, so one half can still work, the loss of a pantograph isn't an issue, that sort of thing.
Track access charges are a major issue too, because of the sliding scale concerning axle loads, EMUs and DMUs, being only a little heavier than an unpowered coach, are only pennies more per mile than an unpowered coach, when you put all the weight into one locomotive, it becomes significantly more expensive per mile.
Train length is another - adding a locomotive takes up 20m of train length, where you're compromised by signal, platform length and points, you might need that 20m length to fit in a passenger carrying vehicle with 50 seats.
There's also power/braking issues. It's easier to get 4MW down when you've got a dozen powering axles, instead of just four. It's easier to brake and recover energy when you've got a dozen axles with motor generators on them.
NSEFAN
17 Jun 2007
Southampton
There's no point in having locos where not needed, as you end up with non-passenger carrying space, as well as a higher weight on the loco axles compared to distributed traction, increasing wear and tear on the infrastructure.
The only reason you would use loco hauled passenger trains nowadays is if there's no other stock available, or for passenger comfort reasons (I.e no underfloor engines).
AM9
13 May 2014
St Albans
As passenger numbers rise, trains have been extended to limits of the infrastructure. With an MU, platform space is not wasted and no provision for further running around is needed.
Philip Phlopp
31 May 2015
That's quite a blanket statement there...
For an equal amount of power and comparable gearing, it's generally true.
To get DMU type acceleration, you need to throw a silly amount of power at the problem, as the Class 68 solution demonstrates.
Crossover
4 Jun 2009
Actually, anything from a bit of a problem to no impact. A Voyager pretty much won't suffer from an engine out at all other than a bit more noise from the others
221129
21 Mar 2011
Sunny Scotland
Given that a lot of voyagers run around with one engine shut off anyway I would have thought it would be 0 impact
GatwickDepress
14 Jan 2013
Multiple units allow much more operational flexibility than loco-hauled stock. Units can attach and divide without requiring additional locomotives or infrastructure (sidings, crossovers, etc). This was taken advantage of by the Southern Railway with their intensive portion workings.
Locos used to be useful for hauling freight as well as passenger trains.
In fact the Class 91 was designed to work freight/sleepers at night - but hardly ever did.
Nowadays the needs of the two modes are different and a passenger loco has little scope for other work.
Class 67 is typical of a dual-purpose loco that has very little of either work today.
Time will tell if Class 68 will do better, and if a Class 88 electric version is viable on passenger trains.
Sorry to bring it up, but locos also don't fit the DOO trend for passenger trains.
Push-pull operation is also less reliable than MU operation, and you need a special vehicle at the non-loco end.
Reliability of the ATW Class 67+DVT sets is very poor.
I don't think we have ever had a good push-pull solution, hopefully the new CAF vehicles will work well with Class 68 for TPE.
BuryBlue
8 Jun 2016
Why is it not possible to have an effective dual mode loco?
Is it because good acceleration AND overall power is impossible to do with the same gear ratios?
And regarding DOO - I'm fairly sure LHCS on the GEML at least doesn't run with a guard/additional personnel - unless you count the person in the catering car.
And I wasn't aware of the Class 68 previously. Obviously Chiltern saw some use for new locomotives, why is it an exception?
221129
21 Mar 2011
Sunny Scotland
No LHCS runs without a guard in passenger service.
Harbornite
7 May 2016
It makes you wonder why some operators chose to go against the trend and use LHCS, especially Transpennine. I was also going to add that multiple units don't need to have complicated running around procedures, although this has been negated by the development of DBSOs and DVTs (as mentioned elsewhere in the thread).
With regards to Europe, the picture is similar. New units have replaced loco hauled stock in the likes of Germany and Poland, but some operators like DB Regio and fernverkehr are also sourcing new LHCS.
Arglwydd Golau
14 Apr 2011
That says it all really. passenger comfort is not a consideration any more. We have (or at least some of us) become used to the constant noise and vibration of today's diesel units.
I was amused some years ago when the press release by ATW (following the introduction of the WG express) talked about 'increased passenger comfort' of the re-introduced old stock. Clearly I had missed their comments about decreasing passenger comfort when they stopped using LHCS previously.
W230
6 Jan 2012
Slow, tired Class 319s accerlerate quicker than HST's. This I know, so I think it's fair statement to say multiple units are quicker to accelerate in general.
The Class 700's are made up of 2 x 4 car (or 6 car) bolted together but they still only have one transformer per half unit. That said, you are spot on about it not failing in the middle of nowhere as the other half is able to power the dead part.
AM9
13 May 2014
St Albans
Similarly, a failed class 700 can be pushed/towed away by another class 700 unit to clear a route much quicker than getting a rescue loco there when there is a queue of units behind it.
GB
16 Nov 2008
Somewhere
All LHCS services on the GEML run with a guard/conductor. No guard/conductor on LHCS = no service.
FordFocus
15 Apr 2015
Class 68s are not slow to accelerate.
They are good locomotives but they are having their issues at Chiltern. Couple of fires, irrecoverable engine shut downs and some software glitches. The coaching stock has it's off days with dragging brakes reported too.
Great trains when they work but as soon as something goes wrong, your stuck there for a bit. Where as with a HST or DMU it will limp or continue on it's journey.
Oh, I agree. But there were no qualifiers on the statement, it just read as *all* units are faster than *all* LHCS. I'd put money on gWr's putative 4+2 HST's being pretty fast off the mark.
It's all about performance really.
Class 67 at 125mph was bought for fast mail and parcels traffic that evaporated more or less the day they arrived.
Heavy freight needs to optimise low-end power up to 75mph.
All LHCS runs with a guard, and the driver is isolated from the train.
Chiltern (and ATW) only use LHCS because of the shortage of DMUs, and redundant Mk3 stock was available (though there are not enough DVTs).
Only TPE has chosen an LHCS solution from new, apparently to get trains in service as quickly as possible.
Then there's the sleepers, which is a niche market (and not high-speed).
VTEC's Class 91+Mk4s are being replaced by IEP (mostly).
AGA's Class 90+Mk3s are still soldiering along, but are expected to be replaced by an EMU solution before long.
Harbornite
7 May 2016
It's interesting to note that Bombardier recommended a UK variant of its TRAXX locomotive design for these services, with the existing stock being retained. I also think that there's more chance of EMU's being sourced for the GEML services than the retention of LHCS.
LexyBoy
Fares Advisor
23 Jan 2009
North of the rivers
Ever seen a class 166 accelerate before?
They feel sluggish but they out-accelerate an HST (obviously only at lower speeds). From regular experience I can tell you that a 165/6 leaving Didcot at the same time as an HST won't be overtaken until it's almost stopped at Cholsey - about 5 miles. If it weren't stopping it would be a mile or two further.
True. But it will get caught which means that at some point the acceleration curve favours the HST. Hence why I said it was a blanket statement - thenorthern didn't make it clear if we were taking 0-30mph, 0-125mph or even 100 to 125mph.
AM9
13 May 2014
St Albans
That is a misleading response. LHCS, as practiced in the UK now is either about to be replaced with much better performing multiple units (class 800/801s), or (the AGA double enders, the Cumbrian releifs and Chiltern's lipstick on a pig stop-gap effort) as a makeshift exercise to get around the shortage of multiple units. So to compare the interior designs of '70s and '80s long distance coaches with 21st century multiple units for (largely) outer-suburban use is a specious argument. If the UK still ran LHCS on shorter services (as is a dying practice in parts of Europe), there would be designs suitable for the routes and their traffic. This would mean higher density seating with 1/3 2/3 sliding doors and a fair amount of airline seating, rather than the end-doors and sets of four seats with tables that some imagine as necessary for LHCS. Stock like that has been provided there since the UK went over to multiple units.
If you are old enough to remember, there were plenty of outer suburban trains consisting of four or five 57ft non-corridor coaches hauled by medium sized steam locos (2-6-4T and mogul tender types), that had seating no different to the hoards of 2-BILs and 2-HAPs running around in 3rd-rail land. Even after dieselisation, they were still being lugged around by class 31s and 33s until the DMUs appeared.
LexyBoy
Fares Advisor
23 Jan 2009
North of the rivers
True - but I think as Philip implied it was intended as a "all else being equal" type comparison. I was replying to greaterwest's comment about 166s being slow - whilst they are compared to other units, they'll still beat loco-hauled.
Obviously if you compare 0-125 mph performance then a unit limited to 90 will not fare well. I doubt there are many cases where LHCS will out-accelerate a unit to the lower of their maximum speeds.
sdrennan
23 Feb 2011
Just back from Switzerland and the seem to regularly use additional carriages bolted onto an EMU . Seen 4 additional to a 3 car emu. They must have high power emu to cope
Best of both woelds
jopsuk
13 May 2008
Best of both woelds
But what do you mean by that? The train almost certainly runs around like all day- there won't be any demand-responsive lengthening or shortening.
There's a rose-tinted glasses view that it used to be the case that station masters would spy large numbers of passengers wanting to board a service and call up the station pilot to bring in a carriage or two off the nearby sidings to bolster a service. I question how much that happened. Even in the steam days most services had a planned formation and many carriages were arranged in fixed rakes, either full trains or part trains. The "flexibility" didn't exist that much, and required a lot of land and manpower to achieve when it was used.
What's much more of a trend recently is for lengthy fixed-formations MUs. Obviously the Pendolinos were among the first of the modern breed (though the idea stretches back to the Blue Pullman DMUs and was the envisaged concept for the HST and APT), with much of the Super Express Train fleet following that pattern (though not all) and much more the Thameslink and Crossrail fleets.
