SouthEastBuses
Why is Marlow a nightmare to electrify?Hopefully they'll be electrified too - albeit in this control period. Henley & Windsor should be simple enough - Marlow is still a nightmare.
I'm not sure Bourne End is a nightmare; (from the cl230 thread discussion) IIRC First Group people think that 3x20m units are feasible on the branch... Plenty of 3x20m AC EMUs around.
Seems unlikely - the approach speed into Bourne End platform is already 15 mph for DMUs (10 mph for anything else) and the platform length is only 47 metres.Could you maybe come up with a derogation solution that used ETCS and very slow approach speeds to reduce the overlaps enough to get a standard 3 car unit in?
[Picture shows except from page 143 of the Western Route Sectional Appendix showing line speeds of 15mph into the Marlow platform at Bourne End]
at some point we will need 2 car EMU/BMU's so maybe a fleet of 2/3 car Aventra's with end gangways as a combined thames valley fleet could make senceThe issues are less with the electrification itself, which would be quite easy IMO, and more around the configuration of the junction at Bourne End - currently the practical limit is 2x23m vehicles in the Down (Marlow) platform. Rebuilding for anything longer would be difficult, albeit not impossible. No manufacturer has anything in their current ranges that fits that bill, and even then it’d be a similar deployment level to the Stourbridge Shuttle - 2 units for 1 diagram. Not at all efficient.
Case could perhaps be improved if there were a bunch of these units, and they could be doubled or even tripled up on Henleys and Windsors; it might make for a more viable fleet. Even more so if the same argument then led to the similarly 2-car infrastructure limited Greenford branch.
So I wouldn’t say the actual process of electrification would be a nightmare - objections from local residents aside. It’s more all the other work that would have to come with it. Never say never though!
An order of 2/3 carriage Class 717 Desiro City EMUs a possible option.at some point we will need 2 car EMU/BMU's so maybe a fleet of 2/3 car Aventra's with end gangways as a combined thames valley fleet could make sence
If you're spending all that money, then can you spare an extra few quid to reopen the route to High Wycombe, too?This will be the most expensive and ambitious solution - but I think there should be a complete rebuild of Bourne End station, relocated underground with two tracks as a through station, with a tunnel then curving to eventually rejoin the current branch line. Electrified from the outset with potential for 8 cars, this could solve the problem of the current turn back. Otherwise, the only other solution is either a dedicated 2 car EMU for the line, or a battery powered 230.
Now the one big question - would the extremely big cost of this rather ambitious project be justified for the amount of passengers that the Marlow line gets? Basically would the potential benefits outweigh the cost disadvantage?
If you're spending all that money, then can you spare an extra few quid to reopen the route to High Wycombe, too?![]()
And yes a 3 car 387 for the Marlow line is actually possible - the Electrostar carriage is 20.3m long, and with the platform at Bourne End being about 70m long (not 85m as I thought in the earlier post), I can see the Marlow line shouldn't be too much of an issue to electrify.
Maybe my expensive idea of a complete remodelling of Bourne Hill won't be needed, who knows.
I would re-check, the up platform at Bourne End is 125m, which does not connect to the Marlow branch. The down platform which does is 47m as previously described.And yes a 3 car 387 for the Marlow line is actually possible - the Electrostar carriage is 20.3m long, and with the platform at Bourne End being about 70m long (not 85m as I thought in the earlier post), I can see the Marlow line shouldn't be too much of an issue to electrify.
Using Google’s aerial view there’s 240 ft (73m) between buffer stop and the point machine. There really must be a practical solution, they haven’t got to gain much length. Can’t they move the buffers by dispensation against standards for a start?The picture from Wikipedia shows a 2 car Turbo in the Down platform, to give an idea (picture shows 2 car turbo in platform, with small amount of length remaining at each end)
Bourne End railway station - Wikipedia
en.m.wikipedia.org
Looking at street view, you aren't moving that buffer stop far.Using Google’s aerial view there’s 240 ft (73m) between buffer stop and the point machine. There really must be a practical solution, they haven’t got to gain much length. Can’t they move the buffers by dispensation against standards for a start?
But as Tesco would say, every little helps...Looking at street view, you aren't moving that buffer stop far.
What do you think?
Also I forgot to say, a 3 car Electrostar would be 60m long. So yes it's doable.I've never been on the line so I don't know. Hence why I'm asking all of you whether the huge cost is beneficial or not.
Using Google satellite measurement, the actual length would be between 70 and 80m. It is possible to run a 3 car Electrostar on the Marlow line - you just need to extend the buffer towards the actual end of the track.
if doing that would it just make more sence to re-site the station to be on a direct curve rather than being a terminal station?Looks like the length isn't quite there.
The only other option might be to re-align the whole platform track into where the present buildings are - though that might require some land purchase in the 'vee' of the junction. Though if you're spending that kind of money, you'd be wanting it to be 4 car-capable.
That sounds like a lot of spare cabs being moved around the system just to allow for 2-car units for Marlow and Greenford.Knowing that the branches are unlikely to be wired, I'd look at a fleet of gangway ended 23m 2 car modular DEMU/BEMU/HEMUs for the long term for GW 769, 165/166 and Sprinter replacement at the start of the 2030's. Ideally with a modular design that caters for diesel-hybrid, battery or hydrogen fuel cell.
Splitting a 2 car set for 3 car formations is an option with a gangway ended units.That sounds like a lot of spare cabs being moved around the system just to allow for 2-car units for Marlow and Greenford.
...provided they have suitable couplings at the inner end and there is a gangway translator plate available. There has been a trend towards more permanent couplers in the middle of units and wider gangways so it isnt certain that units of the 2030s could be formed that way.Splitting a 2 car set for 3 car formations is an option with a gangway ended units.
