Not an obsession with re-nationalisation.
Merely an opinion, based on the passenger experience, that privatisation hasn't delivered and isn't delivering.
Northern and TPEs timetable debacle merely reinforced this. If you had travelled on the same trains as me for the past 27 years (and they are the same trains, just 27 years older and more decrepit than when I first started), then you too might wonder if a different way of operating the railways might work better than today's mess. You might also question what privatisation has actually delivered other than an expensive way of getting a worse service.
I suppose my Pennine backwater might be an exception, the only part of the network not to have benefitted from privatisation, but somehow I doubt it.
Although there's still a lot of BR era stock I would question if you are traveling on services run by the same number of units with the same frequency?
Not knowing where you are based I don't know. However, even if your rural backwater hasn't directly benefited chances are that services which you can connect to have improved, making long distance travel better.
However, can you be sure that BR (had it stayed in existence but given the extra resources that the railways assist to have been given) would have improved your trains?
Chances are the extra money would be spent on the projects that it had been spent on, Thameslink, Crossrail, GWML electrification, new trains for much of the southern region, replacements for the HST's and so on.
Maybe there could have been a few more projects but probably not. Given that most of the perceived "lost money" through profits is through TOC's which is a tiny amount compared to that provided to NR and new projects.
For example HS2 (or in previous years Crossrail) spent more than the gross amount that TOC's returned to the government.
Even if we assume that the rail companies are taking out 10% of the gross that they return to the government that's £76 million. Which isn't that much when the total net government support is circa £4 billion that's not a lot of extra.
However, look at what people complain when the government take a hands on approach. Add an example IEP, where the big complaint is that it is costing more than it should do. As such it's hard to be sure what the actual outcome would be in terms of costs.
It could be argued that the reason that the story under BR was so low was because it was too low compared to what it should be. With some of the extra spend since BR being to make up for that shortfall.
Either way, neither those who support returning to a nationalised railway or staying with some form of privatised system can prove that their system is actually better than the other.
Does that mean that I think that we should stay exactly as we are, certainly not. However we do need to think carefully about how can we make small changes (which are likely to be fairly cheap to do) which could get rid of some of the problems with the current system and try and get some of the benefits from other models that could be used.
