Why put steam engine speedometer on driving wheels?
Peter Fox
1 Mar 2018
I was looking at a picture of Tornado and it has the speedometer connected to the rear, left, driver. The complication is that there's an arm required from the crank pin back to the axle centre. In addition, this can't help access to connecting rod bearings. Why not use the pony truck right under the cab floor?
If it's attached to a driving wheel it will give a clear indication of wheelslip?
pdeaves
14 Sep 2014
Gateway to the South West
Possibly standard type of design; not all locos have non-driving wheels. Possibly also longevity; attaching to a bigger wheel means slower workings inside the 'gubbins' for any given speed.
jamieP
27 Feb 2012
Theres a lot of pipe work etc under the cab making the fitment of a speed there very complicated.
Perhaps because the pony truck moves around laterally on curves so the speedo cable would flex around each time?
hexagon789
2 Sep 2016
The rear driver was the norm for steam locos, if attached to a rotating bogie a torque arm would be required to account for the lateral play. BR did experimentally fit one loco with one on the leading bogie in addition to the usual rear driver, this extra cable was to provide more accurate indication at low speed.
It didn't work and afaik BR went back to tradition.
Pretty much.
