Windermere line electrification progress
Discussion in 'Infrastructure & Stations' started by 59CosG95, 5 Sep 2019.
  1. 59CosG95
    59CosG95 Established Member
    4,420
    18 Aug 2013
    WIM/PBO
    Amid all the Brexit chaos in Parliament yesterday, there was a debate on electrifying the Lakes Line.
    Tim Farron, MP for Westmorland & Lonsdale (the constituency through which the Lakes Line runs) has given it his support.
    https://twitter.com/Rail_Elec/status/1169280312599298053?s=19
    Rail Forums
  3. edwin_m
    edwin_m Veteran Member
    17,347
    Only a couple of hundred more supports needed and someone can start hanging wires from them.
  4. deltic08
    deltic08 On Moderation
    2,453
    26 Aug 2013
    Ripon
    About time. I hope he succeeded in convincing the minister.
    It would only cost £15m or thereabouts and only take 3 months if the branch was closed and bustituted.
  5. LNW-GW Joint
    LNW-GW Joint Veteran Member
    13,829
    One of the issues with the Lakes line is that the western half (5 miles) is inside the Lake District National Park.
    Planning approval for any changes to the infrastructure might be difficult to get in these environmentally-sensitive times.
    This was alluded to by Chris Grayling in his decision to cancel the scheme.
    Of course we now have 80 miles of wired route from Manchester Airport to Oxenholme being run by DMUs, just so they can spend the final 10 miles on the unwired Windermere branch.
    The bi-mode solution once proffered instead of electrification seems to have evaporated.
  6. class26
    class26 Member
    684
    4 May 2011
    This attitude from local authorities (planning permission) is totally nuts. keeping diesel will aid climate change which will destroy the national park much more than a the wires !
  7. Meerkat
    Meerkat Established Member
    2,567
    14 Jul 2018
    Presumably the linespeed and traffic is low enough for fairly subtle metalwork. Subtle enough less pollution pumped into the park outweighs minor visual intrusion.
  8. Mollman
    Mollman Member
    421
    21 Sep 2016
    I seem to recall someone proposed using wood instead of metal poles.
  9. Joseph_Locke
    Joseph_Locke Established Member
    1,831
    14 Apr 2012
    https://www.mottmac.com/releases/mo...innovative-integrated-overhead-line-structure
    The last estimate for electrification was quite a bit more than £15m, and you'd put the loop in the middle (unless you were going to re-create the connection from the Down Main onto the Branch, north Oxenholme, to allow trains to pass there).
  10. Bertie the bus
    Bertie the bus Established Member
    1,473
    15 Aug 2014
    Who are Campaign to Electrify Britain's Railway? A small group of rail enthusiasts?
    Why would they want to discuss the scheme with Tim Farron? His views on it are already very well known but he has about as much influence as I do when it come to government spending.
  11. 59CosG95
    4,420
    18 Aug 2013
    WIM/PBO
    Key industry players in the Overhead Live Equipment sector of rail, amongst other industry players in favour of electric over diesel traction.
    I was fortunate enough to attend their 'town hall' meeting at the University of Birmingham (my alma mater) back in April, and a number of prominent industry speakers were there (David Shirres of The Rail Engineer among them).
  12. GRALISTAIR
    GRALISTAIR Established Member
    3,748
    11 Apr 2012
    Dalton Georgia USA
    https://www.railwayelectrification.org/
    I am also writing a Wikipedia article with references etc. I was rejected but I am editing heavily to improve and be accepted. Feel free to improve please
    https://en.wikipedia.org/wiki/Draft:Campaign_to_Electrify_Britain’s_Railways
  13. Bertie the bus
    1,473
    15 Aug 2014
    So people who would personally profit from electrification then.
  14. yorkie
    yorkie Forum Staff Staff Member Administrator
    45,913
  15. AndrewE
    AndrewE Established Member
    3,434
    9 Nov 2015
    It is NOT an issue
    I haven't seen any evidence yet that the national park might try to obstruct electrification, in fact https://www.thecumbrialep.co.uk/wp-...y-of-Lake-District-line-rail-improvements.pdf says
    and
  16. Grumpy
    Grumpy Member
    659
    8 Nov 2010
    Is that "quite a bit more than £15m" for putting the wire above the existing track, with a further add-on for the loop/re-created connection, or add-on included?
    I suspect many of us outsiders are confused by the costs of electrifying. The RIA cost challenge report published earlier this year suggested a cost of £750k-£1m per single track kilometre. I believe the branch is approx. 16stk which equates to a cost of £12m-£16m. As suggested up thread people seem to expect that the physical features of the branch should make it a relatively cheap scheme. No coalfields, former double track, potential for 7 day access etc
  17. GRALISTAIR
    3,748
    11 Apr 2012
    Dalton Georgia USA
    The potential for 7 day access especially over say xmas-new year but well clear of main tourism season should make it far easier than Manchester to Preston for example.
  18. swissrailpassion
    swissrailpassion Member
    136
    7 Feb 2008
    Well said.
    It is simple common sense to electrify it. That, however, is in very short supply at the DfT.
  19. td97
    td97 Member
    650
    26 Jul 2017
    Environmental concerns definitely aren't a problem. Every project, National Park locality or not, has in depth and detailed environmental studies and reviews etc., which always aim to completely minimise any distruption to the environment. More comprehensive than most on here could imagine.
    Even the local MP, who whinged beyond belief when there were no train services in the aftermath of the May 2018 TT change, advocates the electrification which clearly brings about temporary distruption/closures.
    Time will tell. Nothing electrification-related has happened on the ground in the North for almost a year now (apart from renewals). Although Windermere isn't next (to the best of my knowledge).
  20. fulmar
    fulmar Member
    66
    12 Feb 2016
    Some track realignment would be required. There are three locations where the track passes through one side of an arch overbridge where there is insufficient clearance for the wires. Adding a loop would also significantly increase the complexity of the signalling system.
  21. bluenoxid
    bluenoxid Established Member
    2,003
    9 Feb 2008
    Has anyone stated that they want to operate a second train on the line
  22. twpsaesneg
    twpsaesneg Member
    351
    21 Jul 2009
    Design started on this about 2 years ago but was stopped again almost immediately. At that time the scheme was to allow "passive provision" for a passing loop near but not at Burneside if memory serves. There was some upgrade work required to one of the crossings too.
  23. alangla
    alangla Member
    750
    11 Apr 2018
    In previous discussions, the big feature that reduces costs is that it could be end-fed from the OHLE at Oxenholme with no feeder station required. I’m still surprised it wasn’t done in the 1970s when the WCML was wired, similar to how North Berwick was done with the ECML electrification
  24. Steamysandy
    Steamysandy Member
    250
    29 Jan 2018
    Longniddry
    The 1970s Electrification was to do only what was necessary for the WCML, and no more. Done properly, the entire Blackpool - Manchester - Bolton - Preston and the Liverpool lines should have been done at that time - not nearly 50 years later!
  25. Ianno87
    Ianno87 Established Member
    6,076
    3 May 2015
    Yes, strikes me as an 'obvious' candidate for a blockade in a quiet period of the year to do in a big bang.
    Presumably there wasn't much point without Manchester, Liverpool etc. being done, unless you wanted a lonely no-mates EMU just for the purposes of working the branch shuttle. Better to keep a common pool of DMUs with Barrow, Morecambe, etc.
  26. Elecman
    Elecman Established Member
    1,936
    31 Dec 2013
    Lancashire
    Oxenholme ATFS is a Traction Feeder station so very little voltage drop to feed the Windermere Branch
  27. Class 170101
    Class 170101 Established Member
    5,590
    1 Mar 2014
    Presumably there is spare capacity at said feeder station to cover electric services on the branch?
  28. Bletchleyite
    Bletchleyite Veteran Member
    47,142
    Up and down the south WCML (mostly)
    Yes, there is, that's why it's such a cheap job to wire it, which is why it should be done.
  29. alangla
    alangla Member
    750
    11 Apr 2018
    A 4 car 350 type unit at Windermere branch speeds isn’t likely to tax an overhead feeder sized for 92s or 2x86/90 on heavy container trains or multiple Pendolini doing standing starts from Oxenholme station
  30. LNW-GW Joint
    13,829
    Then why did the SoS use it as one of the reasons (or benefits) for cancelling the scheme and using bi-modes?
  31. AndrewE
    3,434
    9 Nov 2015
    As somebody once said "Well, he would say that, wouldn't he?"
    Has he produced (or has anyone else got) any evidence to back up the claim? Even today I'm not aware that politicians are noted for their truthfulness! Presumably you didn't read https://www.thecumbrialep.co.uk/wp-...y-of-Lake-District-line-rail-improvements.pdf which says
Share This Page
