It has to be said though that this has wanted doing for yonks, and all the more so since Tallow Hill was made into a big road and traffic lights put in at its junction, also the Sherriff Street traffic lights put in at the other end. There are now too many different sets of traffic lights all on top of each other, so that, for instance, when the Tallow Hill lights let go you still can't get across the junction because the tailback from the underbridge is blocking it, and the underbridge in turn is choked by the tailback from Sherriff Street. Removing that single-lane section would do an awful lot to unchoke the traffic flow over quite a wide surrounding area.
It does not require large-scale demolition or anything of the kind, either. It is almost wide enough as it is for two lanes if it didn't have to have the pavement going under it as well; it just needs the single-lane section broadened to the same width as the double-lane bit under the iron spans on the east side, by excavating two or three metres from the south side of the "tunnel". No need to touch any of the buildings as they're all on the other side of Midland Road. Probably the trickiest bit would be not accidentally making the signal box fall down, and sooner or later the area is going to get resignalled after which that problem won't arise any more.
As I've already pointed out, sorting the parking space for Shrub Hill is easy because there's all the redundant siding space behind the station to make a car park with access from Sherriff Street. This is of course accessible from the east without bothering about the single lane underbridge at all.
For people coming from the west it would be far better to provide a station on the west side of the river, not make them go five miles further round the already-congested bypass to a redundant station originally conceived in the 70s as being the best hope for providing some sort of improved service from the Worcester area to Cheltenham/Gloucester/Bristol and unfortunately not dropped when the logic behind that idea was overtaken by events. Which is actually something the county council are considering, they just haven't got their priorities in the right order. By chance the other day I happened upon an old newspaper from 2016 reporting on this idea. I think this:
http://www.worcesternews.co.uk/news...ar_Worcester_by_2030__suggest_council_chiefs/ is the online version of the same article but the link is 503ing at the moment. It should be Rushwick that is due to open soon and Stoulton Road that might happen "by 2030" if only the council weren't, well, a council.
