Worst train designs ever
Jonno2055
9 Aug 2005
Essex
could it be a 144?
No suspension and only 4 wheels per carraige, it really was designed to be a bus on rails, no consideration oon passenger comfort. Get packed very quickley, huge step to get off, if you stand up you wont be up for very long.
Galvanize
8 Jun 2005
South East london
507/508/313/314/315 family:
They make me feel sick, low backed seats, slip and slide too much, poorly maintained (especially the SET ones :x). Only the refurbs are good (yet to go to Merseyside to go on them)
Nick
8 Jun 2005
As far as I can see it, the Pacer design was based on an idea to provide trains at a cheap cost and running cost and quick alighting/arriving via the doors. As such, the unit is fitted with a bus style, in hope they'd open faster than the 'plug' style and wouldn't cost as much as the internal slide doors.
At the time of there construction, a brief was set out to provide a cheap to run 'rail bus' which was a bus but for the rails for many rural lines. Costs were cut on designing by using bus style seating and no bogie structure. In the late 1980's it was an embarrasement by British Rail that they were still using (albeit better than the current 'new' trains) 1960's slam door stock. As such they were ushered out and into service quick without a lot of consultation.
I wouldn't call it the worst design, but it was one of the cheapest!
If it wasn't for the Pacer's cheap design, the then-Tory government would have closed some rural lines.
Nick
8 Jun 2005
My point exactly yorkie, the brief to designs was just that. To provide a bus on rails which was cheap to run for the rural lines.
bunnahabhain
8 Jun 2005
There are no bad train designs, there is bad management of Rolling Stock though, for example would a Class 91+Mk4 stock work well on a Hertford Loop service from Kings Cross?
And likewise would a Class 313 do well on a Kings Cross-Glasgow service?
Trains are designed for specific operation, I dont have much of a problem with the 313-315 and 507/08's, they are commuter trains, it's just that they are put on services they are not meant to be on.
Comments on Pacers have already been made and I second them. :)
Jonno2055
9 Aug 2005
Essex
Every train has certain flaw and yes thinking about it cheapness was the point of the 144 and it looks like it wont be coming off of our railways anytime soon.
Bad management - 317s going to peterborough, 'One - a one way ticket'
The issue I have with them is regarding the layout of the windows & seats: not a single seat lines up with a window. it's almost as if they deliberately decided to deny people a window view! But that possibly could be changed with a thorough refurbishment, maybe.
bunnahabhain
8 Jun 2005
They were designed in the understanding that most passengers would be commuters who travel the route every day and dont really care about a good window view.
Also, the Doors need somewhere to go when they are open, and that's why there isnt much window space.
Seems very odd that they went out of their way to ensure no-one gets a window view, and it hardly encourages leisure travel. The trains are required to work more than just peak hour services.
Jonno2055
9 Aug 2005
Essex
Rail travel was originally designed to be very luxurious if only it wre still like that but was also cheap. Impossible. But aswell as that if you were a commuter would you reallywant to travel on something like that, you just want to get from a to b
KevinR
31 Jul 2005
Yea, the refurbished 508/7's here are a vast improvement over the unrefurbished wrecks that were here. Much more comfortable to ride in, with no more cramped 3x2 seating!
ChristopherJ
8 Aug 2005
London, UK
You wouldn't want to do a 315 from London Liverpool Street to Southend would you. ;)
(YES, 315's are allocated to Southend services in the early morning/late night, eww!)
Or even worse, a 313 from London Euston - Birmingham. :? (apparently happened when the Class 321's were taken out of service about a year ago)
Jonno2055
9 Aug 2005
Essex
315s dont have toilets, i cant remember if 313s have them, if they dont london to birmingham will be a very long journey, its already bad going to southend
Jonno2055
9 Aug 2005
Essex
Galvanize
8 Jun 2005
South East london
I had the misfortune to go on it from Euston-Milton Keynes, but T'was a WAGN one. Got chatting to a couple who booked FC in Silverlink (why i do not know because 87s/90s were still running then to BNS/Wolves) and had to make do with 2x3 standard class seats. I even suggested them changing at MKC for a Virgin service, but they said they'll make do with what they had :|
Craig
15 Jun 2005
Newcastle
142/143/144's aren't really as bad as some people make out. They certainly stopped many lines being closed. The main problem with them these days are them being used on unsuitable routes. I often travel from Newcastle to Hexham, this is an ideal route for them, short route, plenty of stops with relatively low line speeds. They start getting uncomfortable on routes like Carlisle - Middlesbrough.
The same can be said for Voyagers. They're not bad for, say, Newcastle - Birmingham. But longer runs like Edinburgh - Plymouth? No.
Jonno2055
9 Aug 2005
Essex
I hate being on a train, in a car or on a bus for hours, a national express bus leaves you sitting down for 7 hours to get from london to exeter. london to cornwall by train is 5 hours but at least you can get up and walk from the buffet to your seat a few times. Inbetween collapsing at the prices at the buffet, £1.25 for a bottle of warm coke?
Harold
9 Jun 2005
Southampton
I thought at first that the 458 juniper was one of the worst designs because the front looked hideous and they proved to be unreliable
but they gave a smooth ride
also i think that the 150/1 WAS one of the worst designs as well, although i like them
HBA135
T
Tom
Guest
What about 150/0? Only one of them, must be the worst, they only made one!
AlexS
7 Jun 2005
Just outside the Black Country
Actually, they made two. 150001 and 150002. 150002 became 154001 and then got converted back to 150002. The 3 car Central 150/0s are all 150/1 and 150/2 hybrids, that have been renumbered 1500xx, EXCEPTING 001 and 002.
Tom B
27 Jul 2005
As you say - self contradictory.
Pacers perhaps had their use keeping lines open, but isn't it time for a replacement? You can fit fancy new seats and paint them bright pink but it will still be an awful train.
HSTfan!!!
11 Jun 2005
i've been a sworn pacer hater for years and years but more recently I've start enjoying them, they are quite a laugh on the valley's I have to admit. I don't think I've had a pacer fail on me, but I have had 2 x 150/2's fail on me so I hate 150/2's as a result.
KevinR
31 Jul 2005
Now, now lets not hate on them its not their fault, blame the company that maintains them! ;) I've been riding on 150/2's all over the place for years and never once [touch wood!] had a failure of any kind.
Mojo
7 Aug 2005
I had the misfortune to get on one of those, at about 6pm in the evening from Shenfield.
Whilst we're on the subject of 315s, is what 'one' are having done to them supposed to be a refurbishment, because from what I can see, the seats are exactly the same, they're even in that NSE moquette.
Personally, I hate the 158s. Many are filthy, not due to the fault of the train, but due to neglect from their operators, the doors should never have been at the ends of the coaches, the train is very noisy and very hot and sticky because of the Air-con (I understand some TOCs are/have started a test with a new type of air-con).
I'd rather have refurbished a 143 or 150 any day.
5 Jul 2005
House
After todays performance probably TPE scuds. Oh how I hate the minimal leg room so much.
No to mention been stuck in rail traffic for 2 hours stopped dead in 30 C carriages.
Horrible!
metrocammel
11 Aug 2005
Ashton, Lancashire
I dont actually mind 158's, but from where I live to get to Manchester it's ever a non-stop TPE 158 or a via 142 (usually though known to be a 156) via Ashton. So the 158 wins every time. There is no comparison, bus seats v's proper high back seats. 142 and the pacer family just look and feel cheap and nasty inside and out, and even the windows are only protected with a small film, not double glazed like most trains, so if your going through somewhere that flying bricks are a common occurance (like around Gorton outside Manchester or some rough outer-Liverpool estate) your more likely to get injured on a pacer than if you were on a 158 etc.
