BRX
- Joined
- 20 Oct 2008
- Messages
- 3,629
I'm imagining something like a continuation of the BR MkI, MkII, MkIII... sequence.
It would have to morph into something more multiple-unit based but a similar principle: every, say, 5 or 10 years there is a step up to the next version, but within each, things like the basic bodyshell, and anything relating to interoperability would remain constant. There could be variants for different purposes but within reason all would be able to operate with each other. Once the basic type had clearance for certain routes, etc, then all its variants would. There would be common parts. Each type would be well tested before introduction into service, meaning that any testing relating to new introductions would only need to concern itself with where they differed from the basic type.
There would be questions about who would produce the design and specification. But once that existed, there could still be competition between suppliers to produce it.
I know that the IET was a kind-of attempt at this, and didn't turn out all that well, but maybe the key is that it's a core design that should be specified and rigid, and then decisions about exactly what facilities are built in to variants can be made by train operators.
Would something like this be at all feasible in the modern world? Or would you, in reality, end up with so many sub-variants of everything that it would be just as much a mess of incompatibility as we have today? Would it realistically help to avoid the kinds of problems we seem to see as a result of multiple new designs being introduced in parallel, each bringing up their own problems and resulting in delayed introduction, extended periods of teething-problems, and so on?
I realise that you'd probably only see the benefits over quite a long time span. There would be a long period until everything we have in operation at present had been superseded.
