Wymondham to St Pancras International - Via Stratford International
TurbostarFan
8 Aug 2016
Is it possible to excess a Wymondham to London Terminals (Via Cambridge) return ticket to be valid to/from St Pancras International on one of its legs via Stratford International on a HS1 train? Or is the best way of doing it to excess that portion of the ticket to the Via Norwich route and buy a seperate ticket to/from St Pancras International and Stratford International?
Can you clarify what journey you wish to make?
If you already hold any ticket(s), please state which ticket(s) you hold too.
cactustwirly
10 Apr 2013
I think the OP would like to travel Wymondam - Norwich - Stratford - St Pancras International.
I did a search for Wymondham to London St Pancras, using Trainsplit's advanced options specifying changing at Norwich and Stratford, and it is offering
Advance fares, for example £16.30 (undiscounted OS1) departing at 1116 and arriving into St Pancras 1421. This includes validity on the DLR.
Unfortunately it's yet another example of a route that is only available to either Advance ticket holders, or to holders of two or more tickets for their journey.
There is no through walk-up fare that would be valid for travel from Wymondham to St Pancras via Norwich and Stratford/Stratford Intl due to the presence of a negative easement invoked by Southeastern.
TurbostarFan
8 Aug 2016
That is correct.
I hold a Wymondham to London Terminals via Cambridge Off-Peak Return.
With a via Cambridge ticket? I'm not sure it's that clear.
Yes but I wish to excess the ticket in question to enable me to use the Via Norwich route.
No then; as described above the option exists only for Advance tickets.
(By the way, as an aside, please reply to 3 posts using one reply; simply click Quote and Reply multiple times within one post. Thanks!)
TurbostarFan
8 Aug 2016
Will do in the future, many thanks.
I am now aware that the answer is no and that the only solution is to buy a seperate ticket between the two stations. Many thanks to all that participated. :D
TurbostarFan
8 Aug 2016
How come it's possible to do this from St Pancras to Norwich with a single then?
clagmonster
8 Jun 2005
There are fares from London St. Pancras to Wymondham route Plus High Speed. There are no such fares in the opposite direction. Why this is, I cannot answer. It could be an oversight by Greater Anglia. It could be lack of perceived demand. It could be a revenue issue. It could be something else completely.
