XC to Manchester Airport
Discussion in 'Allocations, Diagrams & Timetables' started by bungle965, 18 Apr 2015.
Thread Status:
  1. bungle965
    bungle965 Established Member
    1,748
    2 Jul 2014
    Blackley and Broughton/ Walsall South
    Surely this must be a typo I never knew voyagers were cleared to run down to the airport.
    http://www.nationalrail.co.uk/service_disruptions/currentAndFuture.aspx
    Date of this is 02/05/15.
  2. MidnightFlyer
    MidnightFlyer Veteran Member
    12,588
    16 May 2010
  3. Class 170101
    Class 170101 Established Member
    3,854
    1 Mar 2014
    XC wouldn't have station or track access rights there probably.
  4. bungle965
    1,748
    2 Jul 2014
    So it seems like they will have to reverse twice once in New street and once in Nuneaton, but would it not just be better to use the line from Coventry to Nuneaton line save having to clog up space at New Street.
  5. The Planner
    The Planner Established Member
    7,946
    Considering New St is probably the most important station on the route, no....
  6. ainsworth74
    ainsworth74 Moderator Staff Member Moderator
    17,619
    It would rather defeat the purpose of the CrossCountry franchise wouldn't it...
    :lol:
  7. bungle965
    1,748
    2 Jul 2014
    Point taken, just an idea (not a good one) instead of having to reverse at new street
  8. PHILIPE
    PHILIPE Established Member
    7,648
    14 Nov 2011
    Caerphilly
    RTT confirms - no XC running to the Airport.
  9. Class 170101
    3,854
    1 Mar 2014
    If one is that fussy about reversing at New Street then approaching trains to / from Coventry could be sent via Aston, Perry Barr Jns and Soho Jns and enter New Street from the Wolverhampton end.
  10. The Planner
    7,946
    Considering the dwell times XC tend to have at New St, reversing is neither here nor there.
  11. Class 170101
    3,854
    1 Mar 2014
    True, although whether trains should be reversing at New Street is another matter. I wouldn't have said that New Street is really well used in capacity terms with trains reversing there.
  12. SprinterMan
    SprinterMan Established Member
    2,339
    20 Sep 2010
    Hertford
    New Street is truly a weird case. So many trains terminate there and it only has the one bay platform which is too short to handle the larger trains that serve it and is arguably facing the wrong way.
    Adam :D
  13. The Planner
    7,946
    It is countered by the fact the station is effectively split in two with the a and b ends. It isn't an ideal situation by any means to treat it as a terminal but it does work.
Thread Status:
Share This Page
