Yet, Yet Another BVE4 Command
The Snap
10 Jun 2005
Hi guys,
I seriously think we need a special section for discusing commands now! :D
Anyway, I inserted this for the timetable in my route:
.Timetable(0).Day.Load ../../Railway/Object/Richwell\TT\170_all_stops.bmp
.Timetable(0).Night.Load ../../Railway/Object/Richwell\TT\170_all_stops.bmp
However, I get this error:
C:\Program Files\BVE4\Railway\Route\Richwell Network\RC to AM (Class 323 - Limited Stop - Clear).csv(5) : Cast from string "" to type 'Integer' is not valid.: .Timetable(0).Day.Load ../../Railway/Object/Richwell\TT\323_limited_stop.bmp
C:\Program Files\BVE4\Railway\Route\Richwell Network\RC to AM (Class 323 - Limited Stop - Clear).csv(6) : Cast from string "" to type 'Integer' is not valid.: .Timetable(0).Night.Load ../../Railway/Object/Richwell\TT\323_limited_stop.bmp
Every other route uses this, and it works, but not in mine! :cry: Help please! :D
Tom B
27 Jul 2005
It seems you have a cross of two filesystems there! Windows uses backslashes all the time, Unix uses forwardslashes :. all yours should be backslashes.
The Snap
10 Jun 2005
So, I need to change all my slashed to forward? Or back? :) :?:
T
Tom
Guest
He says backslashes, so backslashes are required kind sir.
Tom B
27 Jul 2005
The Snap
10 Jun 2005
Hi guys,
Still not working! I've changed them all to back slashes and all to forward, but still, no luck! :cry:
T
Tom
Guest
... it's all to backslashes ONLY.
Now, back to backslashes, post your error.
The Snap
10 Jun 2005
I am using this code:
and get this error:
C:\Program Files\BVE4\Railway\Route\Richwell Network\RC to AM (Class 158 - Limited Stop - Busy - Fog).csv(5) : Cast from string "" to type 'Integer' is not valid.: .Timetable(0).Day.Load ..\..\Railway\Object\Richwell\TT\158_limited_stop.bmp
C:\Program Files\BVE4\Railway\Route\Richwell Network\RC to AM (Class 158 - Limited Stop - Busy - Fog).csv(6) : Cast from string "" to type 'Integer' is not valid.: .Timetable(0).Night.Load ..\..\Railway\Object\Richwell\TT\158_limited_stop.bmp
T
Tom
Guest
Try the same line for the code...
