Hi,
Ths cross over at Failrfield IS 15 mph and with the length of the train remains 15 mph until you come to a stand at Fairfield Road Stn. I made the timings for this allowance. I mentioned a 15 mph speed board object but Richard has overlooked this for now. This crossover isn't suitable for any higher speed, unless Richard replaces it with a longer set of points. Because of the gradient you can increase speed from the signal prior to this to 20 mph and shut power off to run down the bank, slowly bring speed down to 15 mph (No. 1 application only) as you reach the crossover. Speed will increase as soon as you release the brakes and you will have to 'rub the brakes' (using first notch appliciation) two or three times until the front of the cab is midway through the crossover, then it will keep speed until you stop in the station.
Likewise, the 25 mph speed restriction between Great William Park and Brentwood is cleared when the front of the 156 is between the 60 mph board and the bridge, where you can start applying full power. With the 158 the front of the cab is level with the back end the first coal wagon on the left. With the Cl66 freight you will be level with the stop blocks of the goods lines when you clear the back end.
With both the 25 and 40 mph restrictions you will probably need to apply one or two notches of power to keep speeds on the binding curves but keep an eye on the speedo as you come off the curves as speed will increase.
The 158 is quite different from the 156 and the subtle difference in the two timetables allow for this. However, both require four notches of power before they really get going from a standing start and in to top notch from 15 mph. The 158 gains with excelleration above 40 mph.
For the run up to the Fairfield Crossover control signal, you can hold the speed at 40 mph right up to the single yellow at Aston Market and shut of power half way down the platform and apply two notches of brake at the single yellow and be at 25 mph at the AWS ramp and then slowly come down for a 10-15 mph creep up to the signal, when it will clear on approach. Then you can increase speed to 20 mph as explained above and handle the brake accordingly for the steep grade.
N.B. Only in BVE are you guaranteed that a signal will clear on approach! On the real railway there is no such thing as a guarantee that a signal will clear, even if it often does. You must always be prepard to be stopped. No if's or maybe's. Don't let anyone tell you any different, no matter how high up the tree they may be. Yes, they will try!
From Fairfeild Road to Naughton you get the fastest run over the route. You can really go for it. The 156 will reach appx 65 mph before the single yellow and the 158, probably, 70 mph. The 321 unit will almost touch 80 mph. Next cruise down to the 40 mph warning board and slowly bring the speed down for the restriction board, when all brakes should be released. You may have to apply one notch of power to keep speed but shut off as soon as you reach the mark and cruise into Naughton. You can be doing 30 mph as you pass the Jumbo jet on the left, in the airport then be doing 20 mph half way along the platform and aim (1 & 2 brake notches) to stop on the mark.The stopping point is almost level with 'end' the white text on the side of the second last coach of the train on the opposite platform.
If you practice these moves you should be able to keep time within reason. You can still do this and keep 'Mr. grumble' (BVE 2) smiling, just go easy with the braking. One and Two notches really do work well. Notch three is 'emergency' and should never be used unless seriously neccessary. If you have to go into emergency brake position then you are not in control of your train.
I hope that this helps.
Here is a question for you! "How long is a speed check"?
Whoever gives the correct answer will be given a free copy of the Richwell Route!!!
Cheers.
Bill EWS.
