Altitude information
Andy873
23 Mar 2017
Thanks as always to everyone who's replied to my other topics.
I have re-worked a gradients profile for my old branch line, however I cannot find information as to the height above sea level for the two junctions that connected it to the East Lancashire line.
Using Internet sites, I can get close to the following:
Great Harwood Junction (Blackburn) approximately 435 feet.
Padiham Junction (Rose Grove / Burnley) approximately 430 feet.
Both junctions were indeed higher up than the line itself, but I was wondering if there is any historical railway information which would give the correct heights?
It's difficult with modern maps as both locations have been built over, and of course the line isn't there anymore.
Thanks,
Andy.
Magdalia
1 Jan 2022
The Fens
I would also like a good source of heights above sea level for railway locations.
When looking at contours on maps, bear in mind that the railway is usually not on the same level as the surrounding land: it will be higher when on an embankment or viaduct, lower when in a cutting or tunnel.
Various summits have location boards with heights above sea level. But that probably doesn't help here!
Ken H
11 Nov 2018
N Yorks
Try https://maps.nls.uk/. Lots of old OS maps there. You may find one thats before the area was built up and when the railway was extant.
(Link takes you to a site to search and view historic map images.)
pdeaves
14 Sep 2014
Gateway to the South West
If you have a gradient plan (effectively length and angle) you can calculate from a known point. Of course, you need the known point to start with!
Andy873
23 Mar 2017
Glad someone else feels the same way as I do.
I did wonder about that, I have the precise distances along the line, it would depend on how accurately the original was drawn. If it is accurate, then we need a little maths here I think.
Thanks,
Andy.
Ken H
11 Nov 2018
N Yorks
Thanks,
Andy.
That will be interesting. Railways have complex curves. Translating a straight line on the gradient diagram to the curve on a map will be fun. Especially if they are different scales.
I would use an image manipulator (MS Paint will do it) to make the map and the gradient diagram the same scale on paper.
Put pins in the map at regular intervals along the rail route. Get some cotton or string. Lay it along the bottom of the gradient diagram and mark off points of interest (say changes in gradient). Then wrap the cotton/string along the pins, and you can then mark the points of interest on the map. You could do the same in reverse, to mark points of interest on the map on your diagram, say a contour crossing the railway route.
(Remembering Technical Drawing and Geography at school over 46 yrs ago!)
Magdalia
1 Jan 2022
The Fens
Yes. But errors in extrapolating from a fixed point could be cumulative. It would be good to have frequent known points for cross checking.
etr221
10 Mar 2018
I do wonder whether - and to what extent - the railway (i.e. Network Rail) actually knows itself. TfL have made available a spreadsheet of station depths (I think via FoI), giving track levels at platforms.
But I am unaware of Network Rail having done the same - to any standard (as to what is covered, or not). While I'm sure some altitudes are known - as they are advertised for some summits, it would be interesting to have a comprehensive set of altitudes.
