Today the water company had to do some emergency work and I was without water for about two hours.
When it came back on, it all seemed fine, all the taps and the shower was working. I have not put on the washing machine on yet though.
However, I flushed the toilet to test it and the cistern wouldn't fill up (the toilet is a modern one and has a water inlet shut off valve)
Mr Google to the rescue, left the taps running etc, not much happened, although I heard some gurgling noise from the cistern once. Back to Google and Youtube, and I'm seeing all-sorts - I don't want to be trying everything, could make matters worse.
Is there a simple fix for this? Or is it worth calling the water company, as they caused the problem in the first place.
Many thanks in advance.
