Are 323s related to Networkers?
py_megapixel
5 Nov 2018
Northern England
I can't help feeling that 323s are very similar to the Networker family, in terms of what types of services they run, their layout/design and even (on electric Networkers as opposed to Networker Turbos) the noises they make
Can anyone confirm or deny those suspicions?
Agent_Squash
22 Jul 2016
Apart from the bogies (which were a common BR design), no.
The 323s were procured by the Regional Railways sector of British Rail and built by Hunslet of Leeds (the only recent passenger trains for the UK main line network and I think the last before they went out of business). They have some stylistic similarities to the Networker fleet which was built a few years earlier by BREL and GEC (now parts of Bombardier and Alstom) for the Network SouthEast sector. Traction packages for the 323s were by Holec of the Netherlands, also their only product for the UK, also now part of Alstom.
One common factor is that 323s and Networkers have the same bogies. The design started with the PEP units and Class 313 in the mid-70s and was used on all multiplie units after that until privatisation except Class 158. It was a BR design and although the rights passed to BREL/Adtranz when that was privatised, they were required to license the design for any stock ordered by BR from any supplier. Hence it could be fitted to the GEC Networkers and the Class 323, but after privatisation when BR ceased to exist it only appeared on Bombardier designs.
Could RR have borrowed the Networker specification from NSE, given that they didn't have any of their own experience in procuring EMUs?
507 001
3 Dec 2008
Huyton
IIRC the management and design team for the 323s was made up of people who had previously worked on the Networker project, hence the similarities.
Roast Veg
28 Oct 2016
There are many time sensitive factors that also dictate the similarities, such as the most viable traction motor inverter technology (GTOs) producing the distinctive gear change sound. Curiously, the IGBTs fitted subsequently also make the noise.
dubscottie
4 Apr 2010
There was issues. Roger Ford detailed the saga in Modern Railways at the time. (I will need to dig the mags out).
I think there were concerns about the loading gauge, signalling compatibility & delivery schedules of a Networker variant.
Met Cam was not that interested IiRC as it was a small build and they were busy with tube stock orders anyway.
py_megapixel
5 Nov 2018
Northern England
The following is possibly incorrect. I'm not an expert.
The noise is, I believe, not solely a consequence of the inverter technology used. A summary of my (almost certainly over-simplified) understanding is that it's a consequence of the need to avoid limitations of older inverter designs. So just replacing the inverters doesn't change how it sounds as the rest of the variable frequency drive will still operate in the same way.
Roast Veg
28 Oct 2016
Yes I'm inclined to believe the same.
dubscottie
4 Apr 2010
Had the full order been realised, there would be 57 units or 171 carriages so not really a small build.
Yes but at the time there was no guarantee. Even if the WYPTE wires had been given the go-ahead at the time, there would still have been a long gap between batches of units.
Hunslet did get overseas orders for the 323 also later on.
Centro had a big say also if I recall. They wanted something "new" not just a electric sprinter.
I will try to dig out the Roger Ford articles later.
tomuk
15 May 2010
The inverters have to switch at varying frequencies to drive the motors at the required speeds. As to not interfere with the line side signals ie track circuits certain frequencies and multiples thereof are avoided. Now with older GTO inverters they are unable to switch as frequently as newer IGBTs and it so happens that the frequencies they are limited to are within human hearing range. The switching design used by Holec making the 323s particularly tuneful.
The 323s were recently updated to IGBTs as the GTO used required special cooling (CFCs) which made them difficult to maintain. To retain their existing safety case it was easier to switch the replacement IGBTs at similar frequencies to the old GTOs.
tomuk
15 May 2010
Re Hunslet TPL who built the 323s. The TPL part of the company was formed by 15 ex Metro Cammell engineers/managers. Hunslet provided the factory and some money.
py_megapixel
5 Nov 2018
Northern England
That's a far better explanation! I knew about the need to switch at different speeds to correctly control an AC motor, and that you hear that switching frequency from the motor, but I never realised that GTO inverters got hot enough to require a cooling system or that the 323 ones had even been replaced. Thanks!
