Article on solutions to congestion at Leeds Station (City Metric)
Chester1
25 Aug 2014
http://www.citymetric.com/transport/here-s-how-fix-leeds-railway-network-3328
How viable are his suggestions? Are any of them planned?
Here’s how to fix the Leeds railway network
By Chris Sharp
Leeds has a problem with public transport. The obvious issue is absence of a tramway: years of lobbying for trams has failed and Westminster has recently blocked a trolley bus scheme.
But there is another pressing transport issue in Leeds: its railway station. Unlike most other large cities, Leeds only has the one station into which all its trains and passengers funnel every day. It’s desperate for more capacity to run more trains.
And the pressure on that station is going to get much worse when HS2 arrives. Passengers in Wakefield, Bradford, Halifax, Castleford or Pontefract currently don't need to go to Leeds to get to London: they either have a direct train or they change at Wakefield. When HS2 opens with its very fast link to London, though, changing at Leeds will become attractive, even at the expense of the convenience of a direct train.
The first option which should be investigated is a second station, something like Manchester's Oxford Road. A site east of the station between Leeds Minster and the bus station would go some way to relieve the pressure. For this to be effective, though, a significant number of trains would have to call there.
This brings me to the fundamental problem with Leeds railway station: the lines that serve it are lopsided. Six tracks enter the station's west side, yet only two tracks leave on the east: in effect, two thirds of the trains arriving at the station have to terminate there.
Terminating a train in Leeds isn't in itself a bad thing, but you can run a lot more trains when they only stop there for two minutes and then head off in the same direction they were already going – you know, like most trains, tubes, trams and buses do at most stations and stops. The key to sorting out Leeds is to rebalance the station to enable as many trains as possible run through the station rather than terminating.
[Image]
A simplified map of the Leeds railway network. Some little used lines are omitted for clarity.
Looking in detail at the trains that arrive in Leeds from the east, they come on a line from Hull, via Selby, and a line from York (trains form Newcastle, Middlesbrough and Scarborough). These two lines meet at Micklefield Junction and run from there to Leeds on a two track railway. Eight trains per hour (8tph) come from the east.
Arriving at Leeds from the west there are as follows.
The Harrogate Line – 2tph;
The Leeds North Western (Ilkley, Skipton, Bradford, Carlisle, Morecambe) – 7tph;
Calder Valley Line (Bradford, Manchester Victoria, Blackpool) – 4tph;
North Trans Pennine (Huddersfield, Manchester Piccadilly, Liverpool) – 7tph;
East Coast Mainline (London, Birmingham, Doncaster) – 5tph;
Castleford Line (Nottingham, Sheffield) – 4tph;
Which looks like this:
[Image]
An infographic showing the west-east imbalance of trains arriving at Leeds.
So: 29 trains per hour approach Leeds form the west. Only 8 continue eastwards. That leaves Leeds with 21 terminating trains an hour, off peak!
The simple solution is to run more of those westside trains through the station. But where would you run them to? There are already 6tph to York: I suppose you could add another, and the same for Hull, but that doesn't help much.
still have 29 on the west. So: to make a significant difference some of those trains that arrive at Leeds from the west need to approach from the east.
Obviously you can't move a city to a more convenient location, but it turns out that you don't have to. Look at a map, and you’ll find that many of the towns and cities whose trains arrive in Leeds from the west are actually east of the city. London is east of Leeds, by about 60 miles. In fact, Castleford, Wakefield, Nottingham and Sheffield are all east of Leeds – yet their trains past from east to west, south of Leeds to enter the station.
This is a big cause of the imbalance. Route these services in from the east and the problem is solved. Here’s how.
London First
Rerouting London trains is the easy bit – so easy, that until recently it used to happen, albeit only one train a day.
The East Coast Mainline from London to Scotland passes to the east, but London to Leeds trains leave the mainline at Doncaster and head west. Continue those trains north of Doncaster to Hambleton Junction and run them onto the line from Hull to Leeds and they would approach from the east.
Routing trains this way, rather than via Wakefield, and you get a bonus because it's a higher speed line: more capacity and its quicker. Win win.
Having reached Leeds from the east trains would continue on westward to Bradford or Harrogate. Such a route is desperately needed by Bradford, and way beyond Harrogate council’s wildest dreams. The key here is for the London trains to replace a current Leeds-Bradford or Leeds-Harrogate service, increasing the number of coaches without taking up track capacity.
[Image]
If the two London trains per hour could switch from west to east, the imbalance would become 27tph-10tph.
[Image]
Progress.
New Classy Route
That was easy – Castleford is trickier, because it requires building new railway.
The Cass line runs east-west through South Leeds, before taking a handbrake turn into the station. Well, it should do: more accurately, the train takes a handbrake turn and then parks outside the station for five minutes waiting for platform and you miss your connection to York, for f-
Sorry, where was I? Oh, South Leeds. What is required is a couple of miles of new railway line in south east Leeds. A link between Stourton and Neville Hill through what is mainly post industrial wasteland would enable Castleford trains to approach Leeds from the east. The service could continue to terminate at Leeds or run on to Bradford Foster Square and terminate there. Once again, the result is a shorter and quicker route into Leeds, another win-win.
Along with the local trains that run via Castleford, regional trains from Nottingham and Sheffield enter Leeds on this line. They would also benefit from switching to this route and continuing on to Bradford Interchange.
[Image]
With a new East Leeds Link line in place, a route between York and Leeds via Castleford would be possible. The hourly Blackpool North to York service could be routed this way. Between York and Leeds and this is a stopping service, which eats up capacity between the Micklefield Junction and York. Route this Blackpool service via Castleford and you get another big win: a direct train each hour from Castleford to York would link up the cheap homes in Castleford and Sherburn to the growing economy of York and its overheated housing market.
[Image]
Is that enough?
Rebalancing the lines in this way will provide Leeds with the capacity needed for the arrival of HS2. If further capacity was required, then it would be worth investigating the reopening of the Harrogate to Leeds line via Wetherby. This would join the Hull to Leeds line at Crossgates.
However, doubling the number of trains approaching Leeds from the east will mean that two track line reaches maximum capacity. Quadrupling the line from Neville Hill to Leeds will almost certainly be required.
Extending that four tracking all the way to Micklefield Junction would be a very sensible investment. This is actually easier than you would think, because a forward thinker in the first half of 19th century decided that a four track railway will be needed one day. He stipulated that all bridges over the railway between Leeds and Selby must give clearance for four tracks.
I propose that the new tracks are built on the north side of the current two. These should be built as the fast lines without platforms at the intermediate stations. In effect this would be the eastern leg of HS3, creating a true intercity route (125mph) between Leeds and York.
Oh yeah, it goes without saying, this route needs to be electrified through to York and Selby.
[Image]
Will it happen?
Rail investment in Yorkshire, the Humber and the North East has been non-existent for the last decade and a half – so I don't hold out much hope for any projects like the ones I've set out.
That said, electrification of the Leeds to York and Selby lines should be a top priority. It is the easy bit of the Transpennine Electrification Project and it will be put to use straightaway by TransPennine’s new bi-mode trains and Northern’s new electrics.
The last five years have seen significant improvements in the North West with electrification, capacity improvements and re-signalling. East of the Pennines all we have received are three small stations on the outskirts of Bradford and the addition of a new entrance at Leeds station.
It's time for huge investment around Leeds to make rail a viable option for the city region. What I’ve proposed here is only the start.
tbtc
16 Dec 2008
Reston City Centre
This sounds like a big impressive fact, unless you know that Leeds has the following platforms for "west side" terminators:
  • 1a
  • 1b
  • 1c
  • 2a
  • 2b
  • 2c
  • 3a
  • 3b
  • 4a
  • 4b
  • 5a
  • 5b
  • 5c
  • 6a
  • 6b
  • 6c
  • 13a
  • 13b
  • 17a
  • 17b
...and the following platforms for "east side" terminators:
  • 7a
  • 7b
  • 14a
  • 14b
...so the discrepancy doesn't really matter so much.
You've got six tracks from the west (which split off into six different directions within a mile or so of the station - Harrogate, Kirkstall, Bramley, Cotingley, Outwood and Woodlesford)...
...whilst the line from the east is pretty much two tracks all the way to Crossgates.
So, whilst I'm all for getting the crayons out and trying to justify some new lines, the central premise here is pretty thin - trying to create a "problem" (diverting lots of services, sticking the Blackpool trains through Castleford) to then come up with a "solution" to...
...not convinced!
There are some simpler boring options I'd rather go for - some skip-stopping (passenger demand between Garforth and East Garforth shouldn't be big enough to delay long distance services by stopping local trains at both of) - some electrification to introduce faster accelerating trains on local services - some standardisation of fleets (so that an incoming EMU on one route can go out on another route, rather than requiring long layovers), but this is just a little bit too... how shall I put it... Crayonista for me :lol:
