Avoiding tunnels - Manchester
tunnels
3 Dec 2022
Telford
Hello,
Can anyone advise if there are any train tunnels between Telford and Manchester ?
Any advice or help is greatly appreciated.
Thank you
Mcr Warrior
8 Jan 2009
Hello,
Depends which way you're travelling. If via Shrewsbury, there's the 468 yd Oakengates Tunnel, almost immediately after departing Telford Central.
30907
On each of the two most strsightforward routes there is one tunnel:
1. Going via Shrewsbury, there is a tunnel between Telford C and Oakengates.
Workaround: start your journey at Oakengates.
2. Going via Wolverhampton, there is a tunnel at Harecastle near Stoke on Trent.
Workaround: from Wolverhampton, take a direct train to Crewe (there are 2 per hour on weekdays) and change again for Manchester.
NI 271
10 Sep 2012
The Doghouse
If going via Shrewsbury/Chester/Warrington, Oakengates, Chirk, Whitehurst, Balderton, Northgate, Windmill Lane, Frodsham, Sutton.
WibbleWobble
19 Aug 2022
If you go via Wolverhampton, there's also a tunnel immediately north of Macclesfield station.
Gloster
4 Sep 2020
Up the creek
As far as I can see from the Quail maps there are no tunnels if you travel via Wolverhampton, Crewe and Wilmslow, but there are two short ones north of Macclesfield on the route via Stoke.
tunnels
3 Dec 2022
Telford
Thank you. If I go from Oakengates will I be able to avoid going through a tunnel all the way to Manchester?
Mcr Warrior
8 Jan 2009
Yes, change at Shrewsbury, and then no tunnels into Manchester inbound via Nantwich, Crewe and Wilmslow.
tunnels
3 Dec 2022
Telford
Brilliant, thanks for this. If I go from Oakengates do I need to change at Shrewsbury? From Shrewsbury are there any tunnels on the way to Manchester? Also is Manchester Piccadilly Station over ground unlike Birmingham New Street where you go in a tunnel to get into the station?
tunnels
3 Dec 2022
Telford
Thank you for helping really appreciate it. Please can I check which line this?
Also there are no tunnels to get into Manchester Piccadilly (unlike Birmingham New Street tunnel to get into the station)?
30907
This route ?
This route?
Yes.
It is the normal route from Shrewsbury to Manchester, and changing at Shrewsbury is usually very straightforward. (Occasionally trains may take a route that avoids Stockport, but that is still tunnel-free.)
PS just before Stockport there is a relatively bridge (below a roundabout) but it is 5 tracks wide so I think you will find that OK.
tunnels
3 Dec 2022
Telford
Yes.
Thanks so much really appreciate your help with this.
Please can I check just before Stockport is it a tunnel or a bridge (are you in it for long? Possibly to avoid it?)
Thank you
Mcr Warrior
8 Jan 2009
Thank you
Just South of Stockport station is a road bridge with a small roundabout on top of it. If you really aren't happy with going under that, you could always travel into Manchester from Crewe/Wilmslow on the Styal line.
Gloster
4 Sep 2020
Up the creek
Would the worry be whether it gets completely dark when going under the bridge or whether it just gets a slightly less bright for a second or two? Those who know the line may be able to say.
tunnels
3 Dec 2022
Telford
I think that sounds OK. Thanks for all your help with this really appreciate.
tunnels
3 Dec 2022
Telford
It is more uncomfortable being in a tunnel. If it's a bridge and less bright for a second or two that's OK. Trying to avoid tunnels like the ones heading into Birmingham New Street.
Gloster
4 Sep 2020
Up the creek
I presume that is the very first bridge south of Stockport station. Looking at google maps, I would reckon that it is about 45 metres long and a generous five tracks-width wide. As there appears to be a signal gantry immediately to the south you are unlikely to be stopped under the bridge. I do not know the area, so perhaps someone else can answer as to whether it is light and airy or enclosed when passing under.
tunnels
3 Dec 2022
Telford
Just had a look on Google maps and it shows the roundabout. Looks like a small one and like you mentioned a good width. Think that'll be OK. I've also contacted transport for Wales as that's the line. Thanks again for all your help. Knowing what to expect manages the anxiety a bit. It'll be pretty high as starting a new job. This definitely helps.
