Best and most predictable place I can find a Class 37 operating near London in July.
16 Jun 2025
Toronto, Ontario Canada
I'm a transport enthusiast from Toronto Canada and will be visiting the UK, mainly London, for two weeks in July.
I’ll be mainly focusing on buses and the underground, but I’m also wondering where I could find a Class 37 and some other older locomotives in or close to London, and if there’s a way to track them by fleet number.
simonw
7 Dec 2009
I'm a transport enthusiast from Toronto Canada and will be visiting the UK, mainly London, for two weeks in July. I’ll be mainly focusing on buses and the underground but I’m also wondering where I could find a Class 37 and some other older locomotives in or close London, and if there’s a way to track them by fleet number.
You should be able to catch a class 57 at Paddington on the sleeper from cornwall, if you can get to Paddington early or late.
You might want to ask on wnxx forum for other info
Iskra
11 Jun 2014
West Riding
The links in this post, may be able to assist you in finding a potential charter train in your time period, but the chances of a Class 37 specifically do not seem high:
More specific train information including timings can be found on the RealTimeTrains website nearer the time
StephenHunter
22 Jul 2017
Stratford is good for freight stuff, such as Class 66s and 86s. The Suffragette and Goblin Lines have a lot of freight on them in general.
norbitonflyer
24 Mar 2020
SW London
I don't know how far out of London you're prepared to travel, (does the old adage that "100 miles is a long way in the UK, and 100 years is a long time in America" also apply to Canada?) but many preserved railways publish their rosters. Here is the Severn Valley Railway:
Because of a recent embankment collapse, the SVR's main steam depot at Bridgnorth is cut off from the rest of the line until late July, so it is currently running mainly diesels - the main diesel base being at the other (Kidderminster) end of the line.
Depending on the date in July, you can have your pick of classes 14 (D9551), 17 (D8568), 20, 37, 50, 52 (D1062), 117 (DMU). The class 37 is rostered for 12th, 13th, and 29th-31st. It may well be out on the 60th anniversary event (27th/28th) as well.
Check nearer the time of course, as rosters are subject to change, especially with machinery over sixty years old!
Peter Mugridge
8 Apr 2010
Epsom
There is usually a 37 stabled at Orient Way, visible and photographable from trains between Stratford and Lea Bridge.
Magdalia
1 Jan 2022
The Fens
There is a Network Rail Test Train, which I think is still usually hauled (or pushed) by a class 37, that does a sequence of tests in the Anglia area every 4 weeks.
The sequence was supposed to have started from Derby yesterday, but was cancelled. It is next due to run on week commencing 14 July.
The train is supposed to come up from Derby on Monday afternoon, and go back to Derby on Saturday morning. On evenings and nights it does its testing, in the mornings it rests, usually Tuesday and Wednesday at Ferme Park, Thursday and Friday at Cambridge.
If you are in London week starting 14 July then it should be possible for you to find somewhere to see it in action, assuming that it runs that week.
16 Jun 2025
Ah ok thanks! I will be there that week so I could catch that given if it runs.
Harpo
21 Aug 2024
Newport
This thread is an interesting reflection on the passage of time when just trying to see a (any!) class 37 is tricky.
Peter Mugridge
8 Apr 2010
Epsom
That's all very well if you know exactly where it's going to be and when you need to be ready to snap.
You can see them long enough in advance, 20 to 30 seconds or so, to be able to aim and snap quite easily; they're nearly always in the same place as well. Also the 720s aren't particularly fast going past there - and if you do miss it you don't normally have more than 15 minutes to wait to get another train back to try again.
Haywain
3 Feb 2013
I'm glad that YOU know, but we should be trying to help the OP here, who is not local and may not be very familiar with our network.
16 Jun 2025
So somewhere that they can only be seen from a passing train won't be much help.
Yeah It’s not gonna work if I can only get one from on board a passing train. I need a proper good shot of one.
Class15
30 Dec 2021
North London or Mildmay line
There was a 37 regularly going along the North London line every week on Fridays with a Class 387 in tow, does this still run? If so, this could be ideal for the OP.
In terms of other older locos, look out for Class 90s (built late 1980s) on runs between Felixstowe and the North-West, again via the North London line, but these seem to have become less frequent of late; there were 10 a day a few months ago.
Also Class 56s (1970s/80s) and Class 60s (around 1990) work freight services for DC Rail on a regular basis, these operate out of Willesden. They typically head out west on the Great Western but some workings take them south onto the Southern region via the West London line.
Lastly, Class 59s (1980s) work Freightliner aggregate services which come in from the Mendips out west into various terminals in London, however, it is pretty much pot luck whether one of these turns up on any given train (class 66s are very common on these too).
Bristol
On the day, a lot of freight operators do share their allocations with Realtimetrains, https://www.realtimetrains.co.uk/ e.g. in the info panel to the left on this link: https://www.realtimetrains.co.uk/service/gb-nr:H54683/2025-06-20/detailed#allox_id=0 it says 'operated by 66725'. If you are after specific locos you can enter the number in the search bar but obviously it is dependent on being allocated to a service to find it.
These allocations aren't perfect and not every operator shares the data with RTT (list here https://www.realtimetrains.co.uk/about/knowyourtrain/), but if you pick a busy station such as Willesden Junction or Stratford and use the 'Detailed' search functions you can get a good idea of trains approaching. There are signalling data maps available to help give you advance warning of trains approaching a station as well (Traksy, OpenTrainTimes, and SignalMaps are the 3 I use most often as they have good coverage and are free but there are others).
