SouthStand
- Joined
- 8 Aug 2010
- Messages
- 285
Is a Peterborough to Birmingham (any) day return valid to Birmingham International?
Thanks.
Thanks.
I don’t believe there’s a specific day return for this flow, just the regular returns valid for a month.
Unfortunately Peterborough to Birmingham Stations is only valid via map BP which is essentially the direct route the Cross country service takes. As such it doesn’t appear valid via Birmingham International and certainly isn’t valid to there via Birmingham.
However a Peterborough to Birmingham International ticket is valid to go in and out of Birmingham and you would be permitted to break your journey and/or start and finish short.
The off peak return is £53.80 as opposed to the Birmingham stations ticket at £48.60 though.
It should now show the 3 relevant stations on tickets on PRT.I guess perhaps Birmingham stations should be renamed since I think it's totally fair for people to think Birmingham International is in Birmingham stations.
May I ask what PRT is?It should now show the 3 relevant stations on tickets on PRT.
In context, it's likely to mean 'Paper Roll Ticket'.May I ask what PRT is?
'Birmingham Stations' is the three primary stations in the centre of Birmingham, New Street, Moor Street and Snow Hill, which should be fairly logical to most people.Or is it the closeness that dictates which stations count as Birmingham?
Sure, if you know that it makes sense, but if you have never been to Birmingham how are you meant to know that.'Birmingham Stations' is the three primary stations in the centre of Birmingham, New Street, Moor Street and Snow Hill, which should be fairly logical to most people.
Birmingham International is a station which is 8 miles away from the centre of Birmingham.
If you've never been to Birminhjam why would the existence of a Birmingham stations group be of any relevance? You would buy a ticket to whichever station you are going to.Sure, if you know that it makes sense, but if you have never been to Birmingham how are you meant to know that.
If you start typing "Birming" on most ticketing sites, the first option you get presented with is "Birmingham (All Stations)". I can quite see how someone might select that option, assuming it gave them a ticket valid to all birmingham stations.If you've never been to Birminhjam why would the existence of a Birmingham stations group be of any relevance? You would buy a ticket to whichever station you are going to.
Yes, it would be much better if it said 'All central stations" or something similar.I can quite see how someone might select that option, assuming it gave them a ticket valid to all birmingham stations.
That's good to see.The forum's booking site explicitly lists the 3 relevant stations rather than using the ambiguous "Birmingham (All Stations)" description at the journey planning stage which is exactly how it should be done.
That would help, but it doesn't solve the problem that even if someone has buys a ticket to New Street, they get issued a ticket to "Birmingham Stations", which they might reasonably assume allows them to travel on to Birmingham International.If that was made an accreditation requirement then just maybe the problem would eventually go away. ( Given the state of the industry that seems a bit far-fetched.)
Well that really ought to be changed. Hopefully some of our EMR staff we have here can pass on a message, unless that bit comes from the Trainline side of things. Does it say the same on Northern for example?East Midlands Trains is even worse than the NR website. It explicitly describes Birmingham International as a "City Centre" station
It doesn't.Well that really ought to be changed. Hopefully some of our EMR staff we have here can pass on a message, unless that bit comes from the Trainline side of things. Does it say the same on Northern for example?
The problem with that is if you don't know which station in Birmingham is the best one for your journey, how do you pick the right one?The forum's booking site explicitly lists the 3 relevant stations rather than using the ambiguous "Birmingham (All Stations)" description at the journey planning stage which is exactly how it should be done.
Look at a map and a timetable?I was looking at booking a ticket to Blackpool earlier today, not knowing whether to choose Blackpool North or Blackpool South, because I don't know Blackpool, how do I know if one option is better than the other?
I did look on a map to understand that either station would be fine, but if I'm flexible in what time I can go, and will book my ticket based on the prices offered, then doing one search for "Blackpool (any)" is better than doing separate searches for both North and South stations and spending time comparing them. In the end that's what I did, on a site that had the option.Look at a map and a timetable?
To be clear, the forum site does still have the group for Birmingham, just the group name is "Birmingham New Street, Moor Street or Snow Hill" rather than "Birmingham (Any)".The problem with that is if you don't know which station in Birmingham is the best one for your journey, how do you pick the right one?
There should at least be an option for "Birmingham City Centre stations" or similar.
Thanks for clearing that up. Out of interest, what is the difference?To be clear, the forum site does still have the group for Birmingham, just the group name is "Birmingham New Street, Moor Street or Snow Hill" rather than "Birmingham (Any)".
It doesn't have the Blackpool group (there are technical differences between different types of group, and where they come from), but I agree groups for cases like that are definitely useful
There isn't a Blackpool Stations group for ticketing purposes; it was abolished in May 1994. Presumably this was to allow better allocation of revenue between the various shadow franchises that were being established at the time.I did look on a map to understand that either station would be fine, but if I'm flexible in what time I can go, and will book my ticket based on the prices offered, then doing one search for "Blackpool (any)" is better than doing separate searches for both North and South stations and spending time comparing them. In the end that's what I did, on a site that had the option.
Thanks, that explains the difference to how Birmingham group works (obviously to benefit the privatised rail industry rather than the passenger).There isn't a Blackpool Stations group for ticketing purposes; it was abolished in May 1994. Presumably this was to allow better allocation of revenue between the various shadow franchises that were being established at the time.
Ever since you have had to either buy a ticket to Blackpool North (BPN), or to Blackpool South (BPS). Whilst walk-up BPN tickets are reasonably likely to be accepted to/from (unbarriered) BPS, as you can always ask the guard before reaching Poulton-le-Fylde or before boarding at BPS, the reverse is much less likely to be true as BPN's barrier staff are notoriously unfriendly.
They weren’t anything specifically to do with privatisation. The fares group Birmingham BR seems to date from 1988. In most fares groups “xxx stations” replaced “xxx BR”, and exactly the same issue (ie not knowing exactly what it meant) would have been in place long before privatisation was thought of.Thanks, that explains the difference to how Birmingham group works (obviously to benefit the privatised rail industry rather than the passenger).
Indeed, these National Rail Enquires "timetable" groups (which some retailers also use to various extents) do serve a useful purposeIt isn't helpful, however, for someone planning a trip to Blackpool who doesn't know which one to search for journeys to.
They can also mislead, which is rather less helpful.Indeed, these National Rail Enquires "timetable" groups (which some retailers also use to various extents) do serve a useful purpose
