Dear all,
I am a newbie after some advice/ help/ suggestions.
Welcome
I will be commuting from Bolton to Bache in a couple of weeks and I have struggled to understand why I some trains are allowed in the return ticket and some aren't ? If anyone could explain the reasons and also if there is a way around this, it would be helpful.
I could start beteen 8.30 and 9 in Bache and finish around 4.30 onwards. On the national rail site the quicker routes for eg. at 06.19 to Bache and the journey from Bache at 17:06 don't have the option for buying and these options don't appear on sites like Qjump. I was hoping to buy a season ticket from Bolton to Bache but it looks like using the trains for the quickest journey may not be possible via a season ticket
ad:
The National Rail website doesn't sell tickets, but it will re-direct you to another site that can.
In this case, the National Rail website tells you that you need more than one ticket for this journey* (Bolton-Preston-Warrington-Chester-Bache) and if you click the Buy option enough times, it does attempt to pass the request for both tickets to a booking site (which, by default for this journey, is ATW), unfortunately it seems that the request does not work when there are 2 tickets to be purchased, so there is an error. To buy the two tickets, you would need to do 2 separate searches on a ticket booking site of your choice (avoid Thetrainline as it charges fees), once the tickets are in your basket you can buy them with one transaction.
However you will probably find Season tickets to be cheaper than individual tickets.
Is there a way around this? Could this be done by maybe paying a bit extra?Any advice would be really welcome
* The National Rail website checks an interpretation of the Routeing Guide to determine if a through ticket is valid by the route in question, in this case the National Rail website's interpretation of the RG is that it isn't. But let's check what is permitted on a Bolton - Bache ticket:
Permitted routes on a Bolton [BON] <> Bache [BAC] ticket
Now, we all know that most passengers wish to use the fastest route but unfortunately ATOC, who represent the Train Operating Companies (and do not in any way look out for the best interests of passengers) deny that this is the case, and the DfT are happy to let them get away with it.
The shortest route is always valid, that should be 40.75 miles via Hindley, Wigan, Warrington, Frodsham & Chester.
Direct trains are always valid, but there are none for this particular journey.
The Routeing Guide can be found here:
www.atoc.org/about-atoc/rail-settlement-plan/routeing-guide
Bolton is a Routeing Point (RP)
Bache is associated with 2 RPs: Chester and Hooton. Both of these pass the fare check rule.
Bolton - Chester:
Bolton - Hooton:
Unfortunately the route you wish to take does not appear to be officially permitted, however similar (but longer) routes are permitted:
EH +
NC +
CH permits: Bolton - Blackburn - Preston - Warrington - Crewe - Chester - Hooton.
GM +
CL permits: Bolton - Blackburn - Preston - Warrington - Runcorn - Chester - Hooton
I believe that this is an oversight. The journey is indisputably valid,
except between Bolton & Preston where a guard could theoretically look up the route and tell you that you must deviate via Blackburn! A guard who works trains that operate between Manchester & Preston is a regular on this forum, I will ask him for his opinion.
Guards will accept tickets that look reasonable. If a ticket looks like it may not be reasonable, then they can consult the Routeing Guide. In this case, a route that is less reasonable is valid, but technically your route isn't valid.
