Entertexthere
Does anyone know whether wagons owned by the big 4 companies and branded with company names were rebranded in any way (be a BR emblem, renumbering, Ect.)
The railway nationalisation act included the nationalisation of all the private owner fleet. These were commonly not owned by whoever's name was painted on the side, but by specialist wagon hire companies, of which there were a number, mostly characterised by names including "Wagon" and "Finance". These had a certain value to these businesses depending on how much future revenue they would get from continuing to hire them out as before, so while they indeed were often dilapadated, especially the coal wagons with wooden bodies which were smashed during loading, there was a revenue stream to be compensated. A further finance source by these companies was provision of wagons on hire purchase, and at nationalisation they were entitled to the remaining revenue from the HP period.-ex PO wagons had a "P" letter added. The BTC bought the fleet , for a ridiculous sum , most of which was fit for firewood.
The hirer/owner of the wagon, in turn, made good money from charging demurrage on their wagons at the receiving end. This is a charge, per day, for the wagon just being kept standing. Many local coal merchants used the wagons as storage, and instead of unloading it the day it was received would just keep it on a siding until they wanted to bag up the coal. It was cheaper than building their own storage facilities, and avoided double handling as the coal went straight from wagon to coal sack. This charging passed to the railway with the wagons, so whille the wagon itself may not have been worth much, the charges for it were worth having.
Although many wagons may have appeared ramshackle, it was common to rebody them periodically. This was cheap, most of the value was in the running gear, and a carpenter working on their own could rebody a wagon quite straightforwardly and quickly. The war had greatly disrupted this, both during and after the war timber was in very short supply, given that it was typically seasoned for several years before use. It was one of the principal reasons for the rapid change to steel bodies.
Its probably difficult now to understand the post-war timber shortage, but during the war a massive amount of woodland and forestry was cleared, mainly for building work (especially concrete shuttering) and pit props. Some went into military production (aircraft, ships) but much of that seems to have been imported. Whole woods were requisitioned and clear-felled, with no thought of conservation. So not only were the felled stocks depleted, but the growing forestry reserve was depleted as well. During the war the shortage even led to the adoption of concrete sleepers on a commercial scale.
Post war, what little wood that was available was required for building, while we had an excess of steel production capacity (even if the iron ore had to be imported). Steel may not have been cheaper than timber, but at least it was available. There were even attempts at steel houses: for instance there were a few in Yeovil which basically looked like they were oversize steel barrels cut in half.
