Bradley Chord:- for how long was it disused?
61653 HTAFC
18 Dec 2012
Something I've wondered for a while (and inspired by previous discussions) is regarding the two curves that reopened in West Yorkshire in the year 2000: these being the Bradley curve, and the double track chord between Greetland junction and Dryclough junction near Halifax.
Based on past discussions on here, both were used for occasional diversions until some time in the 1980s. However my earliest memory of Bradley curve is that it was very much overgrown by the mid 1990s. The curve at the Halifax end was also out of use by then, though I can't recall whether the tracks were lifted or just rusty and overgrown.
So my question is: when were these curves last used, prior to their reinstatement as part of the Brighouse reopening?
TIA.
Magdalia
1 Jan 2022
The Fens
The summer Saturday Bradford-Poole ran via this route until 1986. In 1985 and 1986 it was a portion attached to a train from Leeds at Sheffield. It was the last vestige of a train with a long and fascinating history that I don't have time to go into now.
The route also had a daily through service to/from London up to the introduction of HSTs. Its last incarnation in 1977/78 was a portion attached to 0930 Leeds-Kings Cross and detached from 1804 Kings Cross-Leeds. This has an interesting history too, going back to when it was the "South Yorkshireman" running to/from Marylebone.
61653 HTAFC
18 Dec 2012
Thanks. Do you know if there were any other uses after 1986? In the years leading up to it being reopened it was very much overgrown, with a number of large trees on the trackbed. If my memory serves me right, the track had been lifted at some point and the switches at Bradley Junction plain-lined. No idea if the pointwork was removed at Bradley Wood Junction, as that section of the Calder Valley route had no regular passenger service at the time.
61653 HTAFC
18 Dec 2012
Both curves were taken out of use on 9 May 1988.
Thanks once more! I must admit I thought they'd been out of use far longer until I was told otherwise, simply because of how much tree growth was present in the months leading up to reinstatement. Then again, Healey Mills is a fine example of just how quickly vegetation can reclaim a disused site.
Spartacus
25 Aug 2009
I've been told it's due to the common practice of using ashes on the trackbed. For about 100 years it's great, and inhibits plant growth, but after so long being rainwater 'treated' it turns into an excellent fertiliser!
RedKing
9 Jan 2024
Stalybridge
I've had an (admittedly brief) look online and can't find much information about the Bradley Chord.
Just to clarify, this is the single line between Bradley Jn and Bradley Wood Jn to the East of Huddersfield.
Was it ever more than a single line? I know there was a Bradley station but believe it was on the line between Huddersfield - Mirfield rather than the Chord?
And whilst it's 'good' it didn't close, how did it survive being cut? It has 1tph (on a normal day), isn't typically served by freight and just seems something that would have been prime for closure?
Gloster
4 Sep 2020
Up the creek
A 1961 Ordnance Survey map shows it as double track. The line closed to passenger traffic on 27 September 1986 (last train ran) and to goods on 9 May 1988 (mothballed).
Source for dates: Hurst’s Register.
Mcr Warrior
8 Jan 2009
Would it be correct to state that the 'Bradley Single' chord, which still provides a direct route from Huddersfield to Brighouse stations, and beyond, is around some 1 mile 17 chains in length?
The intermediate tunnel, opened c. 1850, is some 6 chains long.
Think I'm also right in saying that the chord didn't ever have its own standalone station, but Bradley station (closed with little fanfare in March 1950 - presume nothing remains) was once located in the vicinity of Bradley Junction, where, nowadays, the main line still continues in the general direction of Mirfield/Leeds.
Mcr Warrior
8 Jan 2009
Thanks for clarifying. Was going by this early 20th century map of the area. Presume the modern day 'tunnel' is more an overbridge?
1280px-Huddersfield,_Bradley_Wood,_Heaton_Lodge,_Thornhill,_Mirfield_&_Dewsbury_RJD_36.jpg
(Map of lines around Bradley (centre left) in 1911. Source: Wiki.)
AndyHudds
17 Jun 2012
What passenger service ran as late as 1986? A diverted trans pennine service?
Around 1988/89 time we used to ride our bikes along the line. By this time the line had become overgrown and the track rusted. As far as I remember it was single track at this point.
Bevan Price
22 Apr 2010
A limited Bradford Exchange - Huddersfield - Stockport service had run until about November 1966.
It was also used for occasional diversions of Trans Pennine services (Liverpool/Manchester - Rochdale - Brighouse - Huddersfield (reverse) - Leeds until it closed. Then Summer Saturdays only as posted above.
Not sure when any regular freight workings had ceased.
Gloster
4 Sep 2020
Up the creek
A look at the Summer 1986 public timetable (no amendments) shows a 05.58 Bradford-Poole which seems to run this way (Halifax 06.12, Huddersfield 06.43 and Barnsley 07.20) before attaching to the 06.52 Leeds at Sheffield. I can’t find a return working.
EDIT: The 05.58 was Saturdays Only and the timetable ended on Sunday 28 September.
AndyHudds
17 Jun 2012
If you read the entire discussion the answer is at post number 2!
Thanks....but this thread has clearly been merged with another, older discussion, on the matter. Post 8 was a new thread which was started yesterday. Get your facts straight first.
Magdalia
1 Jan 2022
The Fens
Which I did, in post 2!
It may be clear to you, but it isn't clear to me, where post 8 just follows on from post 7.
I appreciate that, if you asked your question before the discussions were merged, then you would not have seen posts 1-7.
The important thing is that you have the answer to your question.
Welshman
11 Mar 2010
Not only the Bradford-Stockports, but there was also an almost hourly dmu service from Bradford Exchange to Huddersfield via Halifax, with some extending to Penistone, running until about the same time.
fishwomp
5 Jan 2020
milton keynes
1980s summer specials - a gem of routes and locos... I did the curve back then behind 47305.
Another use for the line was that DMUs would shuttle over the curve from Huddersfield to Hammerton St depot. That depot closed mid-80s, as did the curve that avoided Bradford and was alongside it.
There's a cab video out there of the curve:
The video shows all trackbed + structures were double track.
I don't know if the "corresponding" curve at Greetland was ever OOU - at least part of it was used for oil traffic to the oil terminal at Greetland on the Halifax - Greetland side.
Gloster
4 Sep 2020
Up the creek
Greetland Junction-Dryclough Junction has the same passenger closure and mothballing dates as the Bradley Curve: see #9.
fishwomp
5 Jan 2020
milton keynes
Thanks. A quick look at the satellite maps shows that the oil terminal branched off from the Elland line just before the curve does.
FWIW, the track inside that terminal is still pristinely weed free, even though the access line is fully overgrown and lifted in parts. That'll be the oil industry ethos/rules of keeping burnable scrub growth away from the tanks I expect.
MadMac
13 Jun 2008
Moorpark, CA
I was involved in the whole Halifax-Huddersfield project and visited Greetland box in, I think, 1998. It had been switched out/“mothballed” for some time at that point.
