Broken Down train at Manningtree on 29/01/15
smudga331
6 Oct 2014
Hello,
Having been caught up in this on the 29th January, following a failed 90 on the set that the old Pretendo coaches were placed. I was quite surprised on how the train managed to get taken off the mainline and into a siding. As no rescue loco was readily available, it was decided to attach a fully laden freight train to the rear (the DVT) and then drive it from the failed 90 at the London end and push it into a siding at Colchester Depot. I was wondering if anyone knew if this was a common practice for broken down loco hauled stock or if it is somewhat of a rarity. I've attached a picture too in case anybody is interested.
Regards.
dk1
2 Oct 2009
East Anglia
Hello,
Regards.
When nothing else is available to rescue & a Liner is behind you then this is the obvious solution & the most expedient way to clear the line. I've pushed a set with another set all the way from Diss to Stowmarket, detrained, then given it another shove into Stowmarket down loop. We no longer have Thunderbirds on the GEML.
DarloRich
Fenny Stratford
Commandeer whatever is close by to clear the line. I have seen a picture of a tamper getting shoved out of the way by a FL 66 hauling the high output ballast train!
47513 Severn
25 Oct 2012
How does the driving work in such a situation? I guess it is all done at low speed but the driver in the centre of the train still has no forward visibilty. Is there radio contact with the driver at the front or some other system?
dk1
2 Oct 2009
East Anglia
We have been known to use mobile phones in the past but nowadays the signaller can put both drivers in contact with each other via the GSM-R cab radio.
TheEdge
29 Nov 2012
Norwich
See this then leads to the most unusual rescue (confirmed)
Has a charter ever been the rescuer? Steam loco? Flasks?
ChiefPlanner
6 Sep 2011
Herts
Once covered a gap in the service from Yeovil Jct with "Clan Line" - around 1987 - an ill 50 died south of there - made all local stops with the steam charter - and kept time. Normal passengers transferred to a fresh train at Salisbury...
smudga331
6 Oct 2014
Thank you all for your replies, I found it interesting and different at the time. It's given me a good read to see different methods that are adopted in a crisis too!
thanks!
James
