Busmiles
mak47
20 Mar 2017
Hello everyone, I'd like to show you a project I've been working on since June last year.
Busmiles is a website designed for bus enthusiasts to log which services and buses you've been on.
The system integrates with Bustimes, meaning it also logs which liveries and even the type of vehicle you've been on!
Everything you log will be available on your own "Buslog" which you share depending on your privacy settings.
Here are some screenshots:
I encourage you to have a look at my buslog here as I can't screenshot every feature.
Pre-registration will begin on the 5th, which will allow you to set up your account before the launch.
If you have any questions, feel free to respond to this thread or via discord.
Thanks,
Mak47
Busmiles will be released on the 12th of April.
Aictos
28 Apr 2009
A good idea, looks to be a very useful tool.
221129
21 Mar 2011
Sunny Scotland
I've just tried it and it seems too fiddly to add journeys. On local city routes with a turn up and go service I'll have no idea on the scheduled time of my bus, it doesn't recognize common stop names so need to waste time with using the map. Also it isn't obvious how you add the vehicle details (unless this is a paid only feature?)
Does it improve if you pay for it? As it stands it feels like it would be a waste of money.
richw
10 Jun 2010
Liskeard
My regular service doesn’t appear for either direction start point, but appears in the first village each way!
the mileage is also considerably lower than the real mileage.
It is however a useful resource for rough information and a friendly competition amongst friends
markymark2000
11 May 2015
Western Part of the UK
Yo add vehicle details, click 'add bus ID' and then input the reg or bus number. I guess if you are on a bus which is so regular, maybe use bustimes.org to find the relevant bus and then find the scheduled departure time. To be fair, for now as it doesn't automatically pick up the bus allocation so you could just simply pick the closest departure (of the right route number) and then put in your bus details. So long as the bus goes the same way as you did, the milage should be no different.
I believe if you pay, you basically get to add non scheduled services (if you got on a bus running dead or a rail replacement bus)
It's based off as the crow flies isn't it though rather than actual driving distance so it's understandable why it may show up different. It will show up more on the longer distance journeys
richw
10 Jun 2010
Liskeard
I know the scheduled departure time. I drive the route, and have the same vehicle every day, hence knowing the actual mileage too as I fill my start and end mileage in on paperwork. My allocated vehicle doesn’t track on bus times.
The route is 49 miles each way, bus miles records it as 37.
richw
10 Jun 2010
Liskeard
I found that BusMiles doesn't recognise one of my usual routes at all! Even though Bus Times does.
It recognises it from the first village to the penultimate village but doesn’t show at either terminus
ACBest
30 Aug 2011
Lincoln
I’ve signed up, and first impressions are that it is really good! I can only really echo what everyone else is saying about the issue with it calculating things as the crow flies - if anything can be changed at all to allow the proper routing of each service to be defined, that would be fab and would yield much more accurate mileage figures.
Also, for drivers in particular, entering dead runs is a pain, as bus depots aren’t necessarily near bus stops.
lxfe_mxtterz
3 Mar 2018
Sarahdale (West of Emmerdale)
A really good and useful site, I must say! I've been using it now for about a week to log my journeys and keep a nice record of the different places I've been. The only issue is - and I'm probably just being really blind and stupid here - but is there a way to view all of your previous journeys, as opposed to just the last five?
markymark2000
11 May 2015
I think you have to do daily stats and do it day by day. I can't seem to find a way to do a never ending list.
lxfe_mxtterz
3 Mar 2018
Thanks, found it. I suppose that's better than nothing (at least all of those journeys haven't been lost!) If a long list of all previous journeys isn't currently a feature, however, it would be really useful to have as an update, perhaps?
mak47
20 Mar 2017
Doesn't work for most of Lloyds Coaches services nor Transdev in Lancashire or Yorkshire
Hi there,
If a service is on bustimes and is not showing on Busmiles, I'd really appreciate a bug report so I can investigate the issue.
If you email it to [email protected] and include the bustimes.org stop URL that would be great.
You can get a list of all journeys from 1 operator at the moment. See this for an example.
221129
21 Mar 2011
Sunny Scotland
And now it won't show a significant number of services from my usual stop that were showing previously.
richw
10 Jun 2010
Liskeard
I’ve found where an operator has posted a future timetable online it’s removed all the existing journeys.
Scotrail314209
1 Feb 2017
Edinburgh
Most of the issues don't seem to be stemming from busmiles, but mostly bustimes as that is where the site receives the data from I believe.
LordCreed
28 May 2014
I've been using this the past few days, and it's not a bad tool. However, there's a few (mostly UI things) that I think could be improved on:
- The Bus Stop Name field could do with being a typeable drop down. This way you could guarantee that the stop name matches exactly what the database is.
- Bus Station bays could probably do with being grouped together. It would be much easier to find the departure as opposed to having to hunt through the bays until you find one.
- Ability to view all journeys in one massive table.
- When on the daily stats page, it would be nice if the calendar showed days with services logged (so these days would be highlighted etc).
mak47
20 Mar 2017
Not sure how you can say that when in both instances the journies show correctly on bustimes.
Hi there,
The Bustimes feed can sometimes have a few minor glitches (Particularly night services). This is usually the case as that page on Busmiles doesn't have many things that can go wrong on that page.
If you haven't already, please email me at [email protected] with a few details to see if I can report and trace the issue, thanks!
The search function isn't where I'd like it to be right now. I will most likely re-work the entire system to make it far more accurate. I suggest using your location/map in the meantime as it's a lot easier to work with.
As for the other suggestions, they're on the (surprisingly large) list of things to do/fix, thanks for your feedback!
theblackwatch
15 Feb 2006
Something you need to consider - will it be able to cope with re-registrations? One of my local companies has used the same plate on several vehicles - in fact, 2 of the buses on my local route have gained new reg marks in the past 48 hours or so (and bustimes is currently logging them as if the 'old' buses that previously carried these plates have reappeared).
mak47
20 Mar 2017
I wasn't actually aware any operators did this, I'm not actually sure how I'd separate it. It might be best to mark it down as a different number/reg and then add the livery/details using the "Add manual bustimes ID" button.
Update 2.15 has released!
Fixed many bugs
Added Flickr images for individual vehicles
Added Bus League
Added a map to daily stats
Added dark mode (beta)
Added platinum stars to daily stats
Added Discord integration (Doesn't do anything yet)
Added new forum signatures (Updates daily)
See underneath for the new dynamic bus graphic, there's the BBcode to add this to your own on the settings page.
