buying SYConnect+ day ticket on train?
njamescouk
8 Apr 2017
I'm travelling in s. yorks. tomorrow and going to get a SYConnect+ day ticket. I'm seeing conflicting information about where to buy one: do northern rail guards sell them on the train? plan b is to take a short bus journey and buy one on the bus - I'm out in the back of beyond...
Nottingham59
10 Dec 2019
Well, the Travelmaster website says you can buy at staffed stations and on board.
"Our rail valid products can be purchased from any staffed railway station. For the 7 & 28 Day products you will need a passport sized photo, or a Railway photo card, prior to purchase. If you travel from a station that is not staffed the day products can be purchased on board from a conductor.
"Available Products: GetAbout+ (1 Day) & SYConnect+(1 Day, 7 Day & 28 Day)"
Which is your starting station, and is it staffed?
njamescouk
8 Apr 2017
penistone, not staffed. I know what the travelmaster site says, but it's not to be relied on. some time ago I tried going to the local payzone place and was met with blank incomprehension when I tried to top a card up.
I'll go for plan b.
robbeech
11 Nov 2015
Not tried for over a year but hit and miss on Northern.
Some said yes and some said no.
Cross country say no and try to prosecute so be advised if you boarded at Penistone and had a valid but tight connection at Sheffield and the Northern guard couldn’t sell you one then expect a lot of hassle from XC even though they’d be in the wrong.
If you have a smart phone they’re available on the Stagecoach App.
its like an M ticket where you have to activate it.
skyhigh
14 Sep 2014
Yes, I agree. But do ask the guard on your first train if they would have been able to sell you a SY+ Connect day ticket, and do let us know!
It is 100% possible to sell a SY+ Connect onboard using the revenue equipment guards have. Some might be unsure how to find it, but I'd expect the majority to be perfectly happy to sell one.
robbeech
11 Nov 2015
If you know this to be true as of today, would you be able to tell people here what to tell the guards to look for on their equipment. I sat with an XC guard (after he had calmed down) for nearly 10 minutes between Sheffield and Doncaster going through alsorts of options and couldn’t find it. And I know that Northern would issue it every time without fail years ago, but more recently (into 2020 at least) they have not been able to, as if something has specifically changed.
Haywain
3 Feb 2013
In the TIS we use in Travel Centres it's found in the Rovers menu, where you simply select SYConnect+. So the key is likely to be whether they know where to find rover tickets in the TIS - if they do, it should then be simple.
skyhigh
14 Sep 2014
I'll have a look this afternoon and let you know the steps to find it.
Right so on the handset guards use it's Fares --> Rangers & Rovers then in the product selection box use the search function, type in 'Connect' and the SY Connect+ is the only option, £8.80 for an adult. It's then sold in the normal manner. It's no different to selling any other rover.
robbeech
11 Nov 2015
Do you think that should be the same for all operators that have trains you can use or is the software likely to be different. Is there a way for an operator to stop a machine selling a particular ticket?
I realise that XC and TPE would rarely have to issue one as the stations are staffed with a ticket office, but a valid tight connection at Sheffield or Doncaster and no prior opportunity would mean they’d be obliged to sell one.
skyhigh
14 Sep 2014
Assuming they use STARmobile and have the same list of rangers we do, I assume they should be able to. We have pretty much any ranger you could want UK-wide available to sell, so I presume other TOCs will be the same. I honestly don't know what setup TPE and XC use, but I'll ask if they're able to sell one the next time I see one of their guards.
Wallsendmag
11 Dec 2014
Both
Both Star Mobile I believe
Nottingham59
10 Dec 2019
Interestingly the SYConnect+ doesn't seem to appear on the NR webpage that lists rover and ranger tickets, so does it count as a ranger/rover?
[https://www.nationalrail.co.uk/times_fares/rangers_and_rovers.aspx]
Though it does appear under Northern's list of Special Offers
Haywain
3 Feb 2013
It’s not a rail product as such, but for retailing purposes it is found in the same place as rangers and rovers.
_toommm_
8 Jul 2017
Travelmaster also have an app if you're willing to use mobile tickets.
njamescouk
8 Apr 2017
sYes, I agree. But do ask the guard on your first train if they would have been able to sell you a SY+ Connect day ticket, and do let us know!
sorry, got the train before I read this. buying from a bus dead easy though, plus you have a valid ticket when boarding the train.
