Temporary Speed Restrictions on the Central, Jubilee and Northern lines
xtmw
22 Aug 2022
Essex
It's going to be a long weekend for the Central Line
About a dozen TSRs in place, with there already being gaps in the service. It's only going to get worse from here. All down to the TRV being defective so the track hasn't been checked!
Mawkie
17 Feb 2016
There are a number of temporary speed restrictions on the Pic for the same reason. Strangely, I did see the TRV out and about this week, but whether it was 'recording' or not I have no idea.
(Is there only one TRV for the whole combine? Or more than one?)
31 Dec 2019
uk
There is only one, however many trains have something called an Automated Track Monitoring System (ATMS) including S stock and 1972 stock (I'm uncertain as to whether any other fleets have it installed). There was another train in the pipeline to replace the TRV - the Asset Inspection Train - however it was scrapped a couple of years ago.
See some board minutes from 2011.
Automated Track Monitoring System (ATMS): ATMS is the continuous monitoring of track condition using in-service trains enabling degradation of the track to be measured, automatically identifying any track related defects and allow maintenance activities to be planned to minimise disruption to passengers. A prototype unit has been installed on a District Line passenger train since 2009; 12 service trains will be fitted with the production system, providing up to two service trains on the Bakerloo, Central, Victoria and Sub surface lines by autumn of 2012; providing information to engineers on the current asset condition while the service is in full operation.
xtmw
22 Aug 2022
Essex
All that has been communicated is the TRV has become defective and TSRs have been required because the track hasn't been checked. Although there's currently a 1972 stock sat in Ruislip depot.
Nym
2 Mar 2007
Somewhere, not in London
2009TS also has ATMS.
It was proposed for 1992TS then later 1996 and 1973TS. The former was filed as too complicated and the latter was cancelled due to TLL not wanting to cough up the money.
We’re now into multiple digits of years since it was raised that the replacement for the TRV in place of the AIT would be needed. Nice to see progress being made on that lovely critical project…
Also no idea what that board paper is on about, it’s only fitted to 9 trains in the fleet, not 12. There were 12 systems bought but only 9 fitted.
My memory is fuzzy but it should be…
12001, 12003, 4233, 4236, 22099, 22106, 22504, 22506 and 22508.
I stand to be corrected on these numbers, it’s literally from a 10 years old memory(!)
Chances are they’re going to ITMP the 72TS down the Central Line for an ATMS survey.
Always was the backup backup plan, except the several parts of it are now life expired, and err, there’s some missing information and things for central line operation. All the engineers that know this are likely long gone from the company by now though.
xtmw
22 Aug 2022
Essex
There are around 19 TSRs on the entire Central Line now. Not going to be a good day tomorrow.
Part of me wonders how the 72TS can run on the Central Line. Has it been made compatible with the signalling? Running during engineering hours?
Nym
2 Mar 2007
There is the possibility of piloting it with something else such as the 62 RAT, but that’s rather err, complicated and unlikely to happen.
Chances are it will be an ITMP at “limited” speed. Although ATMS does need to be close to line speed or at least over 6mph
Central
20 Oct 2017
Irthlinborough
Saw on another site they’re running the Boxing Day service this weekend,TTN99/24new reduced service starts Monday 26th.
xtmw
22 Aug 2022
Essex
TSRs to continue into tomorrow then... It'll be fun using the line tomorrow
xtmw
22 Aug 2022
Essex
I believe there are only 1 or 2 TSRs in those areas mentioned. You should be fine to use the line, just leave extra time for your journey
CarrotPie
18 Mar 2021
̶F̶i̶n̶l̶a̶n̶d̶ Northern Sweden
ATMS? AIT? ITMP?
It’s already run on the Northern Line over the last two weeks. This probably has to be the rolling stock event of the decade for London Underground - I honestly never ever thought we’d ever see a 72 stock on the Northern Line again.
Running it on the Central Line would presumably mean issues with the shoegear. Not sure if that can be worked around or not. We all remember what happened with the CHT 1960 stock…
Nym
2 Mar 2007
There is a high lift shoegear design for 1972TS, one was done for the MPU (Motive Power Unit) for the TCT (Tunnel Cleaning Train), not sure if this was kept by TMU (Train Mods Unit) when the TCT project was finally killed and the MPU unfortunately de-activated and killed, rather than converted for other uses as we'd proposed, but of course no-one wanted to pay for.
bakerstreet
29 Nov 2009
Apologies for off topic but are you saying there is 72 stock actually running in service on the northern? If so do you know when this is next timetabled?
The TRV was seen on the Central but didn't get the data needed !
Do you mean it failed to record data, or it got data but showed lots more bits of track that were less than perfect which has massively increased work needed.
xtmw
22 Aug 2022
Essex
The TSRs east of Leytonstone are expected to be removed in the next 2 weeks. Other TSRs in the Stratford era etc will remain in place
xtmw
22 Aug 2022
Essex
TSRs are now going to be put in place on the Jubilee and Northern lines
So that now brings us to 3 lines having TSRs
Nym
2 Mar 2007
If only they’d have picked up their wallets and purchased ATMS for them lines.
(Automated Track Monitoring System)
Or maybe if LUL/TfL had actually done the mitigation works on the TRV and Pilot Cars
xtmw
22 Aug 2022
Essex
There's been talk of some TSRs being lifted on the Central Line due to the rail grinding works
The TRV has been on test runs to see if it's working or not
