Change ends?
26 Nov 2010
How do you change ends of an engine when driving the other way? In railworks 2..? i.e cab ends..
Crossover
4 Jun 2009
"Ctrl" and "=" and "Ctrl" and "-" if I remember correctly
When moving you will just cycle the cabs without control transferring to them (this includes if you have say 2x166's on the Oxford/Paddington route you will move through 4 cabs.
When stationery, control will transfer to that cab, so, if changing ends you need to be not moving at the time (makes sense really) - it will then default things like the reverser to its default position etc fr the new cab
1812
26 Nov 2010
Thank you for the reply... I found out it was CTRL and + with a lot of messing around lol
Thanks anyway, much appreciate you taking the time to respond.
