absolutelymilk
- Joined
- 18 Jul 2015
- Messages
- 1,404
Anyone have any idea what the linespeed is on the Chester to Manchester line (via Warrington Bank Quay)? (Ideally with a reputable source) Thanks!
The Sectional Appendix for the route will be available on the Network Rail website. It's LNW North.
I think most of it's around the 90mph mark.
Link to that part of the sectional appendix (its a 28.5 MB pdf)
Chester to Warrington (exclusive) is NW3003, page 301 of the pdf. Looks predominantly 75mph.
I'll let the OP or someone else look up the rest.
Nothing like.
75mph Chester-Warrington (with 40 through Helsby and 50 at Acton Grange).
60 on the WCML slows, 50 at Winwick Jn, 20 round the Earlestown curve, then a sprint at 90 to Astley.
Astley is briefly 60 and then 75 on to Ordsall Lane.
Also crippling approach control at Warrington (from the south, using P4), and approaching Chester.
Southbound trains often go slow line from Warrington to Acton Grange which has another very low limit at first (15mph) towards Walton Old Jn.
Expect to hang around at Winwick Jn southbound waiting for the WCML to clear.
Not an easy line to "get going".
That stretch of the WCML (Acton Grange to Wigan) was essentially untouched in the overall upgrade. No tilt (EPS speeds) on the fast lines, for instance.
As far as Chester services are concerned, it hardly affects them as they are not going to break any speed limits between Winwick and Warrington.
Southbound, they often use the fast lines (90/80) anyway.
Nothing like.
Are there any plans to raise the linespeed, especially when the 100mph 195s start operating the Chester-Leeds service, and when Arriva get some new stock, or at least have a higher proportion of services operated by 175 rather than sprinters?
I presume as it's mostly fairly straight, there wouldn't be too many issues raising the speed?
It is fairly straight, but I don't think there are any plans to raise the line speed.
There's the long tunnel at Norton, a long embankment with two bridges over the Weaver and canal (plus the awkward junction from Runcorn).
Helsby junction seems designed to obstruct any increase in the 40mph limit there, and the approach to Chester is very slow with severe approach control into the station.
It's strange though that the Welsh Government has spent money to raise line speeds between Shrewsbury and Chester (now mostly 90mph), but the DfT/NR can't do the same between Chester and Warrington or Shrewsbury and Wolverhampton.
Chester-Crewe is at least 90mph now, bar the curves through Beeston.
Is there any reason why these are so slow? There doesn't seem to be any obvious geographical reason why they are so slow.
In my opinion Helsby junction could be improved if the junction became single lead, possibly with the cross-over moved further north and off the bend.
The Chester approach is at the end of a long descent and was the scene of a freight train run-away into the bay platforms; not impossible to improve a little but would probably require significant track and signalling work.
Regarding the other poster's comment about the connection to the Halton Curve, not clear to me why it should cause issues for the speed on the Warrington line.
