Chose Your First Glasgow Fleet
JumpinTrainz
30 Jul 2018
With First Glasgow about to embark on LEZ in 2022, we’ve seen First already start to make changes and plans for its fleet in the lead up to this. If you could choose the allocation of the fleet in your opinion, how would you have it?
I would start by introducing B8RLEs on ‘the One’ services alongside a handful of E400XLB to assist with the peak journeys to and from Clydebank.
The E300s from Dumbarton would be moved to Scoutstoun to oust the B7RLEs. Thus seeing the 9 fully E300 operated. The 3, 6, 77 and X8 services will also see these. The E400s from the 6 (including Caledonia’s) would be split between the 3, 9, 77 and X8 services. The 90 and 8 services will be operated by Streetlites. The 15/16 would be withdrawn.
New low height E400 City would be ordered for the 6. They would run alongside the E300s.
Lanarkshire routes such as the 240, 255, 263 and 267 would be run by B8RLEs. The 201 would be run by Metrocity buses. Local services would see a mixture of E200MMCs and Streetlites. The 18 and 21 routes would see Metrodeckers. The 262 would be reintroduced from Buchanan Bus Station to Airdrie via Coatbridge in place of the Airdrie section of the 2. This would also be run by B8RLEs.
Ex-Parkhead routes would see E400MMCs for the 2, 60, 61, 41. These would run alongside the E200MMCs and E300s from Lanarkshire to compliment the buses Caley already have. The 46 would be renumbered the 19A and would run from Easterhouse - QEUH via Bridgeton and Dalmarnock. The 41 would be renumbered the 62 and run from Easterhouse - Silverburn via Carntyne and Duke Street.
Caledonia routes would see Streetdecks and B8RLEs on the 38 services. The 38B would be withdrawn. The 38C would be returned back to the 36 and run from Chryston to Glasgow Buchanan Bus Station. The 38E would be renumbered the 38A which would run from Baillieston - Rouken Glen. The 7 would see Streetlites. The 4, 5 and 75 will see E400MMCs. The 57/10/31 would see refurbished B9TLs.
Gingerbus1991
30 Jul 2018
MY SANITY IS FINISHED!...if cash was not a limitation...
(Is there not a 14ft bridge on the 2 route in Coatbridge on Woodside St? Or has First changed the route from what I remember.)
The 2 and 6 would gain New Mercedes Citaro G 18m Artics, due to there capacity I’d reduce the frequency on the 2 down to every 10 minutes, of course taking away any disambiguation from the low bridges on the 2 and 6 routes, I feel that with a suspension problem going unnoticed on a decker it would potentially leave very little room to pass, I wouldnt be risking deckers on the 2 or 6 if it were me.
Whilst I would maintain the Volvo/Cummins fleet commonality in glasgow as much as possible no artic exists at the moment with such engines in the UK in RHD form, Citaro it is then..
The 1, 1A, 240 and 267 would be maintained as is.
The 1B Helensburgh to Glasgow would be reduced to an hourly service with the introduction of the x1(below).
Operation with New Eclipse 3 B8RLEs @13.2m long, with 42, GTS 6600 seats, roof skylights and Alloy wheels.
Services 1D and 1C would be renumbered as the x2 and x3, respectively, this would collaborate with the numbering of the current x4 and the 6A would change to the x6, the x6 operating a Limited-Stop along great western rd to speed up journey times.
The x2, x3, x4, 5 and x6 would all operate with the current 2015 400 MMC’s, the x2, x3 and 1B would also omit Barns Rd in Clydebank, instead using Glasgow Rd after Chalmer Street, the 2, 6, 1 and 1A would continue to service Barns Street.
The New x1 would operate Helensburgh to Glasgow via Great western road, obviously instead of clydebank like the 1B does atm, on a limited-stop basis, with Plaxton Elite B9R’s sourced from Plaxon’s used range, refurbished and there D9B engines being E6 fitted.
The 7/7A would get renumbered as the 62/62A keeping numbers inline with the 60/61 and 64/65, using Volvo 7900e 12m Electrics using OppCharge Pylons at Summerston terminus, Electric buses in the current political and environmental climate we live in is good for a brash PR stint, and they are generally a niche yet seen in glasgow in full, great for a quieter passenger ride as well.
Services 9, 58(60A, renumbered) and current 60 could use Gemini 3 B5LH @ 11.3m, Deckers on the 9 would help them stand out amongst the singles McGills use on the 38, and of course the PR machine on the 9 with its “Hybrid Deckers”.. whilst both the 58/60 would benefit from a new bus whilst doing your bit for air quality in Milngavie and Drumchapel(haha).
The 57, 57A and 75, Gemini 3 B5TL @10.5m
The 21’s and 31’s would use the current MMC’s from the 18 and 75.
Service 18 would use the current 2011 Enviro 400 Diesels, refurbed and retrofitted with an E6 exhaust, New Alloy Wheels, Wood Flooring, reupholstered, White Hanover, USB chargers and Next Stop announcement tech, these have more seating down stairs for the old timers en route than the new 10.3m MMCs chosen.
Service 19 and 19A would be single decker op only.
The 34/34A would, Im afraid get refurbed 2006 B7RLEs, not the current branded buses.
The M11 and M60 would amalgamate on a new timetable as the renumbered 83 service with cascased streetlites, the ugly caetano darts would get burned down and the 81 would get refurbished Streetsh*tes in the hopes to go up against Avondales own heaps.
First have recently said they've seen patronage continually grow on the 500 over the past few years, knowing such is whats likely leading First to buy speculated Enviro 400 CITY Diesels for the route, Id go one better with the Fancy double-door 400XLB’s with substantial luggage racks and GTS 6700 Seating for an ultra comfortable ride, I’d also seek to negotiate to the Airport to actively prioritise traveling to the city centre by bus, as there website is off the bat about taxis and private car use.
The 8 and 90 would use current 2015 Enviro 200 MMC’s, I’d then burn most of the StreetLites.
Using heavily refurbished Enviro 300’s with new E6 Exhausts.
The 3, 77, New 78(C/Centre to Paisley via Partick, Penilee) and New 100 route(The 41 and 9A joined every 15 Mins, but the route would split at Paisley Rd West, one section going to Penilee and Braehead every half-hour, the Other half-hourly bus to the Airport via Paisley Town Centre, connecting the south of Glasgow/Paisley Rd West and Paisley Town Centre to the airport, a few of the Enviro 300’s would be fitted with a single luggage rack for this).
(Midland Bluebird sourced)07/09 B7RLE’s, put through a Facelift and heavy refurb and E6 Retrofitted(they would be exchanged for giving FMB Glasgows 2006 B7RLE’s, of course they would get refurbed for Falkirk).
Services 24(89A to Torrance, renumbered) and New x38(Fastlink = Stagecoach Competition) would use these 07/09’s.
(First Aberdeen’s Euro5 B7RLE’s and E5 Enviro 300’s would be replaced by New Enviro 200 MMC 11.8m buses, With the Euro5 B7’s and 300’s being put through a refurb and E6 retrofit for Glasgow, these would also help replace a good few 2006 B7RLEs throughout the fleet).
The 38/38A/38B/38C/38E would be 38/38A/37/36/35, respectively, the 36 indeed operating C/Centre to Chryston Only via Alexandra Parade and Stepps).
The 43/46/61/63(B10, but renumbered and operated from Glasgow), and New 300 every 15 Mins(87 and 10 connected but with a Half-Hourly extension out to Neilston to complete with mcgills 3), the 88/89, the 88 frequency reduced to every 20 minutes with the 89 maintained.
The 06/07/08/09 B7TL/B9TLs would be put through a facelift(B9’s only) and refurbed inside for these and of course E6 Retrofitted, they may not cover the PVR for all these routes.
The 88 and 89 would use a few unfacelifted B7’s.
(In doing this I’d endeavour these B7/B9’s to be operated to a 20yr old life before replacement).
The B7’s would get new Avid electric engine fans to do away with the Roaring Hydraulic fans, the system would massively quieten these on the road for both passengers and pedestrains while the system is touted by Transdev to improve fuel economy as the hydraulic fans run directly from the engine and the electric fans don’t.
The x85, x87 and reinstated/rerouted Half-Hourly x86(Banton to Glasgow via Kilsyth, Croy, Blackwood then directly onto the M80), the x86 express would also operate with lower fares to battle against the train station at croy which is heavily overcrowded, many also complain that the 89 takes a smidge to long going to glasgow via bishopbriggs, hence the reason many clamber to the train station, plus kirkintilloch already have express buses, disposing with the need the previously operated x86 ever had to go to glasgow via Kirkintilloch/M80.
The x87 would reroute in lenzie to use Lindseybeg Rd and Initiative Rd.
These routes would get New Enviro 400 CITY 10.9m Diesels fitted with comfortably superior Lazzerini GTS 6600 seats(the current 2015 MMC’s used on these would be cascaded to assorted city centre duties, namely the x2, x3, x4, 5 and x6)
The Cumbernauld x5, x80 and x4 would make a return with the x80 via central way/m80 using Plaxton Elites, the x5 using low-floor buses via North Carbrain and condorrat ring rd, the x4 would run with deckers from seafar to glasgow via Central Way, Condorrat Main St, st maurice's high school, westfield Rd then directly onto the M80.
(For a higher level of comfortable coaches through cumbernauld it wouldnt hurt for Midland Bluebird to operate there x36\x39 partly with coaches, it would help complete on a like for like basis with stageys x24’s etc).
All routes would certainly undercut the cost of the train and definitely stagecoaches fares.
If last but not least and with enough drivers possibly gained, I’d have many retiree 2005 B7TL’s refurbed to compete on a like for like on major routes in the paisley town/inverclyde area, such as the 23 and 26, McGills would not like it but Im sure that deregulation was ment to bring about more competiton and ergo lower ticket prices after all, plus as I’ve said before much of glasgow has not adopted to the Tripper Ticket.
route101
16 May 2010
18 swapping 68 plate E400s for 11 plates jings .
For me id change the 9a , 57a and 38 branches to different numbers . Bring back the 54 .
The 2 would use deckers , busy e300s are no fun.
The 6 would prioritised for low height deckers and they would stay on the 6 , low height is wasted on a 4.
SPT supported weekday nightbuses.
Does the one need to go to St enochs?
Gingerbus1991
30 Jul 2018
Yeah, I've got a serious hang up about the 10.3m MMC first use, the 18 is used by many old pensioner, there isn't enough seating down stairs.
route101
16 May 2010
I would bring back bendy buses to Glasgow if i was in charge.
Ha , didnt really enjoy going on them , awkward layout , if i was packed was hard to get off the bus as the rear exit doors werent used. Better a decker as you nip upstairs and out the road
SarahDFIG
9 Jan 2019
Lanarkshire I would do the following
201: low height deckers (can't remember bridge height that possibly could stop deckers)(Bellshill is 4.3m so low height is fine here)
240: low height deckers
242: (earlier starts from OV/Pather to Maxim and same at Evenings back to Pather/OV) wishawhill would not be served at night and 240 could then serve retail park with 242 picking up craigneuk scheme.
255: e300s
266: e200mmcs from 240 or e300s from 201
267: e300s
Would also introduce a new route into Lanarkshire which would be interesting.
Lanark/Carluke to East Kilbride via Hamilton Bus STN which would then double back onto motorway to EK. Using E300s
JumpinTrainz
30 Jul 2018
255: e300s
267: e300s
The 240 and 201 can get busy throughout peak but I think they work well with E300s/E200s they don’t really merit a decker service.
SarahDFIG
9 Jan 2019
They both do well at times with these vehicles but would definitely benefit from deckers. Specially as they are the busiest routes in Lanarkshire.
Sounds slightly similar to Mckindless X21 Lanark to EK that didn't last long.
Mckindless did run it with a bus every hour or 2 from Lanark. ALX200 was used on it
route101
16 May 2010
Ive seen this on some rural routes but take the 31 , last bus to EK at 2120 , after this two shorts to Carmunnock , after Carmunnock run these as by request to EK .
