Class 158 air conditioning
gareth950
3 Nov 2013
So, another period of hot weather, and yet again passengers complaining of cooking on class 158s due to faulty air con. I myself was one of those passengers on Wednesday. When a green GWR 158 pulled in to the platform at Bristol TM I expected that as it's obviously just come back from an extensive refresh/refurb that the time would've been taken to fix the air con whilst it was away. But no.
So, as the 158s will be around long past 2020, surely as they are refreshed or refurbished to meet 2020 standards the air con can finally be fixed at the same time?
With sophisticated climate controlled environments in modern cars now, passengers will expect similar conditions on long - medium distance train journeys. It's unacceptable in 2017 for passengers to be baking on 158s for medium distance journeys in hot weather!
I know the air con units of 158s were designed for use with CFCs which immediately made them redundant when they came into use, but that was 25 years ago! Do their sister 159s have the same air con problems?
mugam4
24 Feb 2016
It's gotten to the point now that on hot days I use GWR on the shortest leg possible into aircon land, and immediately change. All guards will say is that "it's been faulted", but considering the problem has been ongoing over a number of years this doesn't seem to have any result
broadgage
11 Aug 2012
Somerset
Not been on 159s much recently, but when I did use them the air conditioning seldom worked in hot weather.
SWT seemed to largely give up on the air conditioning on the 159s and instead fitted a few more very small, partially opening windows. Certainly better than nothing, but not really enough.
bunnahabhain
8 Jun 2005
158 aircon is only designed to keep the temperature approximately at 21 degrees depending on the outside temperature. It is also only able to cool 38Kw of heat per hour, which is roughly equivalent to a half loading without any solar gain. The issue is further compounded by some members of staff thinking they're doing great customer service by opening the windows because somebody feels warm, but not turning the aircon to vent mode, or off entirely thereby damaging the system by forcing it to overwork.
All the pre-2000ish aircon needs ripping out and replacing with a modern system.
The problem is, who pays?
Something does need to be done with the fleets where air conditioning is routinely unreliable. If it is not going to be made to work then opening windows need to be fitted and the air conditioning ditched.
Of course this issue isn't just confined to older trains, see the class 700 thread for another example. At least Electrostars and 158s have at least some openable windows.
superkev
1 Mar 2015
west yorkshire
Until the operators are penalised financially for running defective trains I fear maintaining or enhancing the air con will remain a low priority.
Pity as for medium distance journeys particularly the more powerful 400hp 158 and159's are probably the pick of the dmu's.
K
fgwrich
15 Apr 2009
Hampshire
I would say that least the Liebherr system fitted to SWTs units, and some of the ScotRail fleets does seem to be pretty reliable. Not least in some of the warmer temperatures we've had this week.
One feature I do dislike and it is related to the GWR livery is the painting of the Turbo and 158 roofs in Matt Black. Not the greatest of colours to use if your Air Con below isn't very effective in my mind. The 166s have had work carried out to them at Long Marston, but until they receive a Chiltern style Air Cooling system as part of their future refurbishment, I fear they'll sink back to levels as before. Unfortunately the 158s either need the Liebherr system or something similar.
PHILIPE
14 Nov 2011
Caerphilly
The GWR 158s didn't go away for exam/painting that would include the air-con. It's a far reaching problem that has been with us since they were built in 1989/90 and not a quick Works fix. TOCs twitters keep telling passengers to inform the conductors so that may be able to adjust the temperature. They can't. The problem lies with the product itself and it makes me wonder if the ROSCOs are interested enough to deal with it.
Might want to refresh with the topic which was previously discussed here:-
http://www.railforums.co.uk/showthread.php?t=126669&highlight=158+airconditioning
23 Nov 2015
The ROSCOs pay up? They own the trains so it's their responsibility surely?
Or Government pays up because a) they bought the trains (as BR) originally and b) at least some of the issue is a legislative change than banned the use of some refrigerants and forced replacement with less efficient alternatives.
Crossover
4 Jun 2009
Northern is similar either works fantastically well or not at all. Unfortunately, on Saturday when the temperatures weren't quite so high, it was working far too well and by the time we had gone from Leeds to Carlisle, it was rather chilly. The heat of the week has probably broken that once working air con system since though :P
GW43125
8 Dec 2014
I find SWT desiros like that. You either freeze or bake. Once I walked into the front unit and could see my breath! but 1% of the time it does work properly, take today for instance, it was glorious!
Blindtraveler
28 Feb 2011
Bring on the fridge I say!
I had 4 different Northern 158s over 2 days last weekend and each and everyone was nice and cool with 1 of them acceptionally so to the point where stepping from train to platform was noticeable. Say what you like about them but Northern do seam to know what to do with 158s. Those praising the Scotrail sets I think we must have different experiences as Iv not had a cool scotrail unit in years
Laryk
11 Jun 2011
Taiwan
How can the LM 158s be working fine. They haven't got any
Read like this:
Interesting, I find the LM ones almost always working fine. Maybe a little cold for some but I like it like that.
61653 HTAFC
18 Dec 2012
Right now I'm on the middle car of unrefurbished 158757. Air conditioning working well, getting on at Batley was like going into a walk-in fridge!
topydre
2 Jan 2012
The 158 from Borth to Aberystwyth today was awful. All windows open but still baking hot. One woman with a walking stick opted to leave her seat on a packed train and stand in the vestibule because it was slightly cooler there! I pity those who'd been on the train since Birmingham!
1230 from Cardiff to Portsmouth today was a blue 158 with no aircon in the middle or last cars. At Bristol the (very helpful) conductor announced that there would be a delay waiting to fix that problem, but 20min later they had "found a solution" which was to run the train, still with the same problems, out to Lawrence Hill and back round the Rhubarb Curve so the driver was in a cab with working aircon for the rest of the journey. Not sure what they did when it got to Portsmouth. Also passed a green 158 at Abbey Wood with windows open on 2 out of 3 cars.
cjmillsnun
13 Feb 2011
The ROSCOs will pass the charge down in increased leasing costs. Operators don't want to pay more for the same train. Even if the air con does work!
Kite159
27 Jan 2014
West of Andover
158706 this afternoon working a Wick service was quite warm. I wasn't the only passenger to take advantage of the usual "waiting for a delayed train to arrive" break to get some fresh air.
gareth950
3 Nov 2013
edwin_m said:
1230 from Cardiff to Portsmouth today was a blue 158 with no aircon in the middle or last cars. Also passed a green 158 at Abbey Wood with windows open on 2 out of 3 cars.
Sounds like it's mainly the GWR and ATW 158s that have the air con faults with Northern and Scotrail 158s being more reliable. Different ROSCOs or just luck?
Parallel
9 Dec 2013
Newly refurbished 158950 had failed aircon in at least two of the three carriages today! Thankfully the return journey on 158952 had working aircon!
LiftFan
27 May 2016
The SWT 158s and 159s I have ridden have always had much more reliable air con - the GWR 158s are terrible when it comes to being any sort of cool, especially as the windows are always locked shut...
LowLevel
26 Oct 2013
They're awful - I'd happily spend all summer on local services to avoid them. Some aren't too bad but it's not unusual to get on a unit with it's fluids plastered all over the vestibule ceiling and the fateful 'air con next b exam' in the repair book.
SpacePhoenix
18 Mar 2014
Would it be financially viable (given the age of the 158s) for GWR to replace the entire air con system in their 158s with the system used by SWTs in their 158s/159s?
I don't know if it would as that would very much depend on their franchise agreement, but in railway terms units built in the mid 1990s are not old, so their age is not really a consideration. They are likely to run for at least another 15-20 years, I would expect, unless there is a major class-specific issue like corrosion.
