Class 175 mysterious disappearance
Entertexthere
15 Sep 2018
WIthin L&Y territory
Hi. I was checking realtimetrains for shewsbury and I couldn't see any working scheduled for the line. Usually coradias are commonly found on the Manchester service so I'm questioning whether the fleets been taken out for refurbishment or a problem required the entire fleet to be pulled or even if they've been relocated to a line deeper into wales
Kite159
27 Jan 2014
West of Andover
Are you confusing what RTT is saying?
Code:
Timed for 100mph max
Pathed as Class 158 (Express Sprinter) DMU
As RTT doesn't recognise the 175s for that bit (same with some other modern DMUs)
_toommm_
8 Jul 2017
Further to what Kite said, the 'pathed as a 158' is whats called a timing load - TOCs will often use the slowest train that could be allocated onto that route, in the event of that train running the service so that it doesn't lose time. But in some cases, like CrossCountry, there's no specific timing load for their 170s, so they use 158s as it would be comparable.
The only TOC IMO where timing loads are fairly accurate at the moment is LNER, although this can obviously be affected by engineering works and last minute alterations.
Lanley
1 Aug 2016
Virgin Trains West Coast are also pretty good for this
43074
10 Oct 2012
Class 170 timing loads do exist but the fact they don't show on RTT is because of how it translates the schedule data, so taking Southern as an example trains operated by 171s are timed using a Class 170 timing load, but show as Class 158s on RTT. You get similar discrepancies with cancellation information - e.g. cancellation code "TI" is a rostering error but RTT displays it as a train planning error, again it's all to do with the way that it interprets the data feeds which supply the information.
