Class 28 workings in the mid-late 60s?
HighlandSpot
29 Jan 2022
Edinburgh
Hello,
Does anyone have good resources to see the kinds of workings Class 28s were on towards the end of their short lives? I know they were all allocated to Carlisle by then. How far in each direction did they go at this point?
Also, would a Class 28 have ever hauled an inspection saloon?
Cheers!
Deepgreen
12 Jun 2013
Gomshall, Surrey
Hello,
Cheers!
As an aside, is the BR emblem in your avatar deliberately reversed?
Strathclyder
12 Jun 2013
Clydebank
It may be a tad on the expensive side, but I'd heartily recommend Anthony P. Sayer's book on the Co-Bos.
To cut a long story short though, they were generally used on local passenger and freight work in/around Carlisle, Lancaster & Barrow as they gradually filtered back into stock after their Dukinfield rehabilitation work. The Cumbrian Coast Line featured in their sphere of passenger/freight work, as there is photo evidence of one (linked below) hauling a nuclear flask train (single-handed I may add) at Sellafield, or Windscale as it was still called back in the 60s. At least two were also used on a trial on Tunstead limestone trains in 1963-64. Perhaps surprisingly, they were actually considered superior to the two Class 40s they worked alongside as part of this trial, but Derby Type 2s ended up being used in the event. That aside, the furthest south they likely got post-Dukinfield on a semi-regular basis were visits to Reddish Depot on the Woodhead Line for tyre-turning and other light maintenance work.
(all linked images copyright of their respective owners)
Magdalia
1 Jan 2022
The Fens
All of the fleet went to Barrow after rehabilitation at Dukinfield, but they moved to Carlisle in two tranches: D5700-03 and D5714-16 in November 1965 and the remainder in December 1966, which is when Barrow lost its allocation of main line locomotives. So the Carlisle locos probably carried on doing some of the work that they used to do when based at Barrow.
I would agree regarding the Sayer book. It has lots of detail, but doesn't have very much on what the locomotives actually did. The chapter "operations: a high level summary" takes up less than 10 per cent of the book, and more than half of the chapter is pictures.
The photographic evidence is the most helpful, and the Sayer book has lots of pictures. The CoBos were working in an area that still had steam, so lots of photographers were lineside. But on the other hand not all of them wanted to use up their film on CoBos.
I haven't checked through the book to see if there are any pictures of inspection saloons.
Strathclyder
12 Jun 2013
Clydebank
Indeed. It may not be for everyone, but all things considered, I personally think that it'll be one of the go-to reference sources for the Co-Bos for some time to come.
CE142
23 Dec 2014
I have seen pictures of them on passenger services on the Furness line.
Gloster
4 Sep 2020
Up the creek
Up until the Cumbrian Coast timetable was reduced in April 1966 they had a few passenger workings as far as Workington, but after that there few of them. They appeared on mail and goods, though I think mostly towards the Barrow end. They did work around Heysham a fair amount. (Culled from various sources, so more an impression than anything else.)
Bevan Price
22 Apr 2010
I had one (from Lancaster to Preston) on the 13:03 Workington - Manchester Victoria in 1965.
E27007
25 May 2018
July 1968, I was at Carnforth shed, a CoBo passed by in the up direction hauling a train of oil tanks, I believe that the oil tank train was one of their regular diagrams.
I attach a link to an image of a CoBo on such a train at Carnforth.
1967 Carnforth CoBo
The train was not bogie stock, perhaps there may be images which show the exact type of tank wagon of the workings
postscript,
A link to a CoBo on oil tanks:
CoBo Oil tanks
HighlandSpot
29 Jan 2022
Edinburgh
Would it have been possible for a 28 to have been hauling an inspection saloon (possibly engineers or divisional manager) at any point? I've seen a variety of locos hauling inspection saloons including 24s, 25s, 22s, 47s, etc.
randyrippley
21 Feb 2016
unlikely as they had a red circle coupling code, weren't the inspection saloons all blue star?
Unless the saloon was hauled rather than the more usual propelled
Cowley
15 Apr 2016
Devon
If this is related to model railways I wouldn’t worry too much. If you like the models then go with it I reckon.
Although it would have been unlikely to see a Cobo with an inspection saloon it’s not totally impossible.
HighlandSpot
29 Jan 2022
Edinburgh
I've seen some hydraulics hauling them by themselves in the west (at least one 22 and one Hymek). I wonder if a CoBo was ever in a similar situation? I know the western region was lacking blue star locos in the 60s/earliest 70s though.
Gloster
4 Sep 2020
Up the creek
There is no problem about hauling an Inspection Saloon as long as the brakes are compatible. Propelling is a different matter, as the driver can’t clearly see ahead and the loco inspector in the saloon can’t control the loco. However, it was done at slow speed as the inspector should have a brake handle and in emergency could throw out the anchors.
