Class 334 banging noise
Eng1Alpha
23 Jul 2016
Hi
I am a daily user of Scotrail's 334 train and on a recent journey there was a loud banging noise from the underside of the train. Almost like someone was striking the underside with a metal pole. It happened at various times. Braking-accelerating-idle.
It was loud enough other passengers were startled each time it 'pinged'. The best description is similar to a cat spring when it snaps.
Just curious, but any info welcome.
Car Spring! Oops.
Peter Mugridge
8 Apr 2010
Epsom
Was it definitely from the underside?
My first thought is it's the vacuum circuit breakers operating on either side of a neutral section, but I would expect the noise from those to be from the roof area.
ExRes
16 Dec 2012
Back in Sussex
Could it have been some Remainers hanging onto the underside of the train while trying to sneak into Free Scotland from England?
:idea:
Eng1Alpha
23 Jul 2016
Hi,
Yes definitely underside. It was directly beneath our feet. I thought maybe a loose brake pipe. But it was a very loud deafening ping.
NotATrainspott
2 Feb 2013
It's not a compressor. It's almost as if there's hard parts of the body and bogies which are sometimes coming into contact.
bengley
18 May 2008
Most likely a knackered bush or something on the suspension - not dangerous but definitely something which should be fixed sooner rather than later.
318259
11 Jun 2011
They've always done that from time to time. It's not just a noise, you can actually feel an impact through the floor.
I always thought it was either the suspension or something like a loose stone or Irn Bru bottle being flung up from the tracks and hitting the underside of the train.
7 Jan 2010
Anti-roll bar bushes a regular one.
This^^^
Failing that, damper bushes, bump stops making contact due to incorrect vehicle heights,traction centre bush worn, just about any part of the underframe mountings loose / bushes worn.
