Class 66 types
Casper
7 Jan 2018
Hello
I'm also researching the Class 66 at the moment and see there appear to be three types based on the type of engine they received.
12N 710 G3B-EC for UIC I
12N 710 G3B-U2 for UIC II
12N 710 G3B-T2 for Stage IIIA
Platform 5 (British Rail Locomotives and Rolling Stock) only lists them as "standard" and "low emission"
I believe that "Low emission" refers to the Stage IIIA ones. That might be a bit of an assumption.
I also see that other versions are ones that Freightliner changed the motor gear ratio for both their "standard" ones as well as their "low emission" ones.
Would anyone happen to have a list that correlates the locomotive number with which type of engine it has? Seemingly there are 3 types based on the engine?
There is some great information collated by https://www.class66data.net/ but it doesn't mention engine spec in their data.
Any information is most gratefully received
thanks
Casper
hwl
5 Feb 2012
Hello
thanks
Casper
the platform 5 definition of "low Emission" is confusingly UIC2
There are effectively 8 variations of 66 around with 3 engine varieties leaving the factory but some have been modified since:
UIC1 296 Still in UK [Originally 001-230, 401-410, 501-572, 601-->622 701-->]
1. "Original" UIC1 with no DB stop start (DB GBRF Colas)
2. UIC1 with DB stop start (DB (Circa 140+ locos)
3. UIC1 with FL stop start (FL)
4. UIC 1 regreared for 65mph max with FL stop start (FL)
UIC2 60 Still in UK [3xx-->, 411--> 585-599, 623]
5. Original UIC2 (DRS/GBRF)
6. UIC 2 with FL stop start (FL)
7. UIC 2 regreared for 65mph max with FL stop start (FL) 623
euro 3a 747-779
8. Euro3a (all 31 with GBRf)
GBRf have upgraded a few of their UIC1 with some newer equipment
Casper
7 Jan 2018
Wow! Thank you
Is this engine assignment to emission standard therefore correct?
I'm very impressed with the assignment you have for loco numbers to emission type. There's considerably less Stage IIIA than I previously thought.
Couple of questions if I may re your reply
I appreciate the 66s seem to move around fleets quite a bit and get renumbered in the process but would you happen to have a list of the original number the loco received and the engine type too?
I'm basing these next questions on the 2018 Platform 5 data:
and your info UIC I: 001-230, 401-410, 501-572, 601-->622 701-->
Euro 3a 747-779
001-230: All good. Platform 5 lists the next two as 66238 and 66250 which become 66788 and 66789 respectively. 238 and 250 are UIC I as well then?
3xx---> Plat 5 lists just 301-305 (as does https://www.class66data.net/fleet-list.html). All ok. They are therefore UIC II
401-410 isn't listed in the Platform 5 data. It starts 66/4 from 66413.
This list https://www.class66data.net/fleet-list.html doesn't have 66401-410 either
What happened to those 401-410?
411---> would tally with the Platform 5 data listing 66413-66434 which as you say makes them UIC II
501-572, all ok. Your info makes them UIC I
585-599, all ok. Your info makes them UIC II
(what the fate and spec of 573-584)?
601-622, all ok. Your info makes them UIC I
623, your info makes this UIC II
66624 and 66625 are UIC I as well? Is 66625 the highest of the 66/6 numbering?
701--->
Gets a bit confusing here
701-717 are listed by Platform 5 as being "like 66/0" so presumably therefore UIC I?
Plat 5 lists "718-751 as 66/0 except 718-732 and 747-749"
So 718-732 are UIC I? 747-749 are UIC I or Stage IIIA?
so that leaves 733-746 as? it notes them with engine 12N 710 G3B-T2 so therefore UIC II?
I note your point that
Euro 3a 747-779
780-789
-Plat 5 lists as "like 66/0" so presumably UIC I again
"66/8 Standard design as 66/0 - Colas Rail locos" with
66846 (66573)
66847 (66574)
66848 (66575)
66849 (66576)
66850 (66577)
So UIC I and that part answers the above 573-584 query!
Just 66578-584 missing
66/9
Freightliner
66951
66952
Both "as 66/3" so UIC II then?
66953
66954
66955
66956
66957
These are also listed as Freightliner but 669xx since the 66/5 list was full and they are 66/9 and "as 66/5" which are "as 66/0" so presumably these are UIC I as well then?
Thanks so much for the info thus far and for any further clarifications!
66s seem to be a complex fleet to track!
kind regards
Casper
Nym
2 Mar 2007
Somewhere, not in London
There's also modification variants, such as the remote uncoupler locomotives, TVM430/KVB modified locos, and TVM430/KVB built locos converted to TPWS Four, Tripcock fitted, etc etc.
hwl
5 Feb 2012
Wow! Thank you
Maybe ;) and bit more too
Euro 3a 747-779
EWS ordered 001-250 but 231-250 are in Europe or have got renumbered on sale.
now 733-737 and 742-746 (ex 841-846 and originally 406-410)
574-577 now 847--> with Colas 578-581 to 738-741
No UIC2 - in Europe with Freightliner, 625 highest numbered
701--->
Just a little
718-732 UIC2, 733 ex 401-->405 738 etc see above, 747-749 imported EIIIa from Germany
Euro 3a 747-779
780-789
10 bought from DB recently e.g. 008 became 780
66846 (66573)
66847 (66574)
66848 (66575)
66849 (66576)
66850 (66577)
66/9
Freightliner
66951
66952
66953
66954
66955
66956
66957
yup but different ROSCO too to 5xx
Ordered in 27 batches
kind regards
Casper
Casper
7 Jan 2018
Thank you both!
I'll collate all that and may be back with more questions!
