But ICWC can't use 57 Pendolinos and 54 HS2 sets.
390s will be getting on for 27+ years old when HS2 starts up with its new trains.
#MML
Timing is perfect.
You heard it here first.
Why would the MML need them when they have 33 810s Also what happens to the west coast 805s and 807s#MML
Timing is perfect.
Well, that's certainly two announcements that people weren't expecting on this thread!#MML
Timing is perfect.
My prediction is the 390s will be needed for some sort of service launch on HS2 as the Hitachi/Alstom Derby combination will see seriously late delivery.#MML
Timing is perfect.
Actually I heard it from you on another thread first, but who's counting. Assuming there's life left in them I agree with you!
The cracks are unrelated to the Kobe Steel scandal, although Hitachi did purchase aluminium from them which was used on the 80xs. The cracks are believed to be as a result of Hitachi specifying a grade of aluminium for the components in question that wasn’t a good enough grade for the job. That’s Hitachi’s fault, they should have specified the right grade of aluminium.
Plenty of time to get all the issues sorted. From Dof T announcement
Would they keep or disable tilt?The first train is expected to roll off the production line around 2027. Following a rigorous process of testing and commissioning, the first passengers are expected to be carried between 2029 and 2033
And with MML electrification finishing in the same time window, where could the Pendolinos go![]()
I know this is only your suggestion / rumour, but would they even fit in St Pancras? And what would whoever is operating the route at the time do with regards to 5/10 portion working?Correct. One assumes the lesson has been learned here!
But surely a 9 car would struggle to fit into St Pancras, let alone an 11car?Would they keep or disable tilt?
Good to knowThe Class 810s which were specifically configured to fit in St Pancras are a pair of 5x24m sets, ie 240m total. A 9-car 390 is 218m long which would fit easily.
WCML is far more curvy compared to MML but if went to tilt the line has to move to absolute geometry which has a higher cost in track maintenance better off just spending the cash on getting the Mk3A overheads (and the coaches back!) upgraded for 125mph.Keep it - that’s the whole point of my suggestion! The MML is perfect for tilting trains.
HS2 won't be using Pendos. They would rather take the embarrassment of opening late.My prediction is the 390s will be needed for some sort of service launch on HS2 as the Hitachi/Alstom Derby combination will see seriously late delivery.
Trans Pennine?And with MML electrification finishing in the same time window, where could the Pendolinos go![]()
Trans Pennine?
Plenty of bends between Manchester and Leeds
Cut them down to 5 cars each and give them to Northern.
Because, someone always tries to offload some old stock up here so I thought I'd get ahead of the curve![]()
Well, they did have 5-car 180s...Cut them down to 5 cars each and give them to Northern.
Yes. But someone always says... etc.That would be the same Northern which has seen over 100 new trains delivered to it in the last 3 years, or is there a different one?
Wasn't that just the one hire from Grand Central in the morning peak? I think they were still doing so, pre-Covid.Well, they did have 5-car 180s...
Every day's a school day - I have no recollection of them at all. Ta.It was 3x units used (largely) on services heading towards Blackpool from Manchester, sub-leased from East Coast but came direct, and returned to First Great Western (They never turned a wheel in passenger sevice for East Coast in the end)
