....and also because of the widespread use of rail grinding trains in recent years.
Long-ish tunnels tend to accentuate the sounds of roaring rails because of the echo in the confined spaced.
1950s/60s-vintage jointed flat-bottomed rails on wooden sleepers tended to be very prone to the corrugations that cause roaring rail,,,,especially on very soft or very hard ground and in shallow-ballasted tunnel inverts. When I transferred to Skipton as a driver in 1991, large sections of the Settle & Carlisle and Settle Junction-Carnforth lines still suffered from this problem, but relaying with continuously-welded rail and steel or concrete sleepers with deeper ballast has largely eliminated the problem - except in tunnels - on the former line....but, as
@InkyScrolls correctly states, it's still quite a problem on the latter line, which has seen no wholesale relaying for the past 40-50 years.
The noisiest sections on the Calder Valley line nowadays are all in the tunnels....Elland, Bowling, Wyke, Hipperholme, Beacon Hill and Summit.
