SWRtrainfan
Not sure if it happens on other LU lines too, but I've noticed on the Jubilee Line at least, the trains brake more quickly on the underground sections and more slowly on the overground sections. I'm curious as to why?
It's true on some lines, the newer ones had less freedom in their route so it fell out of fashion. Even on the lines that have it, modern timetabling demands faster progress and trains use power to maintain speed on the uphill sections designed for deceleration.Is it also the case that the underground stations are humped, i.e. the stations are higher than the tracks either side to aid deceleration and acceleration, whereas the tracks through surface stations are generally flat?
Yes this happens on the Central tooNot sure if it happens on other LU lines too, but I've noticed on the Jubilee Line at least, the trains brake more quickly on the underground sections and more slowly on the overground sections. I'm curious as to why?
I thought this only applied to the Victoria ?Is it also the case that the underground stations are humped, i.e. the stations are higher than the tracks either side to aid deceleration and acceleration, whereas the tracks through surface stations are generally flat?
No, I think it was first done on the Central line but it might have been earlier. You can actually see it if you stand at Bond St or TCR and look along the tracks - you can see the next station and the rise and fall of the tracks (whilst remaining behind the yellow line of course).I thought this only applied to the Victoria ?
To add slightly more detail, surface ATO brake rates on CBTC / TBTC lines and the Central line can be set to different values, for example with lower brake rates often set during periods of poor adhesion.Exactly that. There are different braking rates for surface and tunnel sections, and this applies across the TBTC/CBTC lines.
Probably because there’s more chance of a slippery rail on the overground sections ?
Is this an issue specific to LU TBTC? Or also TBTC systems used worldwide?Sort of. But the real reason is that the TBTC system has a design issue that results in the train losing communication with the system should excessive wheelslide occur, which then results in a significant delay whilst a process is followed to “re-enter” it. So a low brake rate has been chosen for the open sections to reduce the risk of this happening. It’s a problem that’s never been able to be addressed, unfortunately.
In fact, you can see it at one end of the Central line stations (Holland Park - Liv St). The stations were extended some time after they were built. So one end of the station is sloped as that section was originally the beginning or end of the tunnel.No, I think it was first done on the Central line but it might have been earlier. You can actually see it if you stand at Bond St or TCR and look along the tracks - you can see the next station and the rise and fall of the tracks (whilst remaining behind the yellow line of course).
I think it's pretty much standard in most underground lines to do that
This can be an issue on any ATO system that uses tachos on driven/braked axles to derive its exact position by the distance travelled - for example it occasionally occurs on the Central line despite various system design improvements and Leaffall season measures.Is this an issue specific to LU TBTC? Or also TBTC systems used worldwide?
Only some parts. I noticed quite a decent on the southbound coming into King's Cross St. P, for instance.I thought this only applied to the Victoria ?
CBTC uses track mounted tags for primary and axle counters for secondary.I'm not aware how TBTC/CBTC calculates how to get to the next station, does it do this via the tags/lineside equipment?
I'm quite surprised to see that Central Line uses wheel revolutions for stopping the train. The stopping position seems quite precise. As the wheel size wears down, wouldn't it affect the distance calculations?For context, the Central Line ATO system works on wheel revolutions. It will count how many revolutions there are to get to the next station. Of course in the wet the wheels spin faster so the ATO system will just stop because it gets lost. Usually the messages "LOW ADHESION" or "ATO OVERSPEED" begin piling up on the DTS. If this doesn't occur, usually the train will pull up to a station a couple cars short, so the driver will have to put the train into CM. If the starting signal is at danger they'll have to be quick!
Usually why you see lots of drivers in CM in the train, or of course the line controllers may send out an instruction to suspend ATO in a certain area.
I think the Victoria was the first to use a saw tooth profile with a sharp gradient just at the station to help acceleration/deceleration. Previous lines had a more gentle slope.I thought this only applied to the Victoria ?
I’m certain the Central London Railway opened in 1900 had this. And there are certainly Victoria line stations where it doesn’t apply. Can’t speak for City and South London (though King William St was def approached upgrade). Also not sure about the 1898 Waterloo and City Railway.I think the Victoria was the first to use a saw tooth profile with a sharp gradient just at the station to help acceleration/deceleration. Previous lines had a more gentle slope.
AFAIK Jubilee didn't bother as the thought was regen braking would be better aicbw
Interesting. Do you mean that stopping precisely at red signals also relies on the wheel revolution counter?[...]
This is generally OK enough for Signal stops (although the "homes" at Liv St WB and Stratford can be a bit close) and can be accommodated for in station stops once the distance to stop is adjusted once the ATO sees the PAC marker on platform entry.
Presumably the number of wheel rotations between PAC markers (what does that stand for? Are they visible or are they radio beacons?) can be used to inform the train how big its wheels are today.and can be accommodated for in station stops once the distance to stop is adjusted once the ATO sees the PAC marker on platform entry.
LU CBTC uses the rear control for primary and only the front in case of failure to resetThe trainborne CBTC/TBTC/ATP/ATO controllers & associated interfaces are normally in the leading car. Some systems (including 4LM ?) have the the facility for the trailing car equipment to be used - I think this was mainly as a backup for equipment failure, but I think it has been found useful for these adhesion issues
