I have done a couple for other jobs in the past so maybe able to help. What kind of things is It asking?
What role this for btw. I am waiting to hear back for the Manchester Driver role.
It's for a conductor at BlackburnI have done a couple for other jobs in the past so maybe able to help. What kind of things is It asking?
Do Northern not require you to live within 45 min drive? I know some don’t mind relocation..I have done a couple for other jobs in the past so maybe able to help. What kind of things is It asking?
Not sure about peak or off peak etc. It could even be done by computer during the initial sift and you could be unlucky that it checks during a busier time!? I’m just guessing but I applied for a role last year that is 45 mins away during off peak times and it failed me almost instantly but when the job was reposted I applied again with exactly the same application and it went through... Railway recruitment is a bit of a lottery at times I feel.Yes still require 45 minutes as far as I know. I think it really strict to help narrow everything down people. so if its not 45 minutes according to google maps you won't get through.
Ive never understood if its peak or non peak times. Could anyone clarify that
Just general google maps
I didnt even get to the testing stage this time :-/. Just trying to find out why.
So are you saying that you did the tests for a conductor position and passed them, then applied for another conductor position but haven’t been invited to test?? If so, is it not likely that your test results will be on file and have carried you through already, assuming they are in date?Not to interview but I already work for Northern and some colleagues were saying some people will get calls for interviews shortly then coronavirus happened.
Just to clarify the two tests Northern are currently supposed to be using for Conductor applicants are:
Numeric Reasoning
and
Verbal Reasoning
There shouldn't be a deductive reasoning test appearing on the SHL system for conductor applicants, there is one available for SHLs customers to purchase, but that is probably a mistake for conductor jobs, it's far, far more difficult.
Perhaps reading some Arthur Conan Doyle books will helpHi I'm struggling on the deductive reasoning online test for Northern Rail.... has anyone got any tips?
Cheers
