Disruption and cancellations at Hastings: Any more information? (04/02/2022)
parkender102
21 Dec 2010
Hawarden
Any idea of the reason for current cancellations at Hastings (The usual non specific 'an incident' is all that is being reported). My daughter is trying to get back to London and everything cancelled till 14:00. If it's a fatality then I assume the lines won't be open any time soon so I'll direct her to take one of the buses being put on to Tunbridge Wells. It looks like trains are still running from Bexhill so maybe better to take a Taxi to there assuming they are accepting tickets from Hastings.
The forums advice would be much appreciated! As always local knowledge is of great help.
24 Oct 2015
A quick Google of National Rail website and it shows all lines now reopen obviously with delays as service recovers.
Below taken from website
Some services will terminate and restart from Bexhill where possible. If you are travelling between Bexhill and Hastings you should delay travel until later.
Southeastern are running a replacement bus service between Hastings and Tunbridge Wells, if you are travelling towards London you may want to use this and connect with a train service from there.
Need2
15 Jun 2016
Suicidal male. Fortunately it has all ended without any ‘trouble’.
Roast Veg
28 Oct 2016
A grim prospect. The Hastings line might be exceedingly slow, but the south A21 is generally awful even after the Lamberhurst bypass.
gimmea50anyday
8 Jan 2013
Back Cab
Would be interested to know why tunbridge wells when Battle and Wadhurst are perfectly reasonable turnaround locations and usually used during engineering work blockades.
so services are returning to normal but is the marsh link to Ashford a viable alternative route? Otherwise pick up a service at bexhill and if necessary change at Lewis or Brighton.
Roast Veg
28 Oct 2016
Robertsbridge was used more often than not as far as I've experienced. At Battle the level crossing is on the wrong side of the station and would have to remain closed for quite some time.
gimmea50anyday
8 Jan 2013
Back Cab
Makes sense, mind the last time I travelled on the route it was still in the hands of Jaffa Cake liveried CEPs…
Surreytraveller
21 Oct 2009
Possibly due to crew workings
30907
Because there are slightly more trains there?
