Bantamzen
All services are currently cancelled through Bradford Interchange due to a fire on Mill Lane close to the line going into the Interchange. Its a pretty big fire so its unclear when services will be allowed to restart:
www.nationalrail.co.uk
National Rail Enquiries - Service Alteration Details
The gateway to Britain's National Rail network. A portal into UK rail travel including train company information and promotions; train times; fares enquiries; ticket purchase and train running information.
A large fire on a property near Bradford Interchange has resulted in all lines being blocked. Trains are expected to remain disrupted until the end of the day tomorrow. An image can be viewed here.
How is this affecting the train service?
Trains are unable to run to and from Bradford Interchange.
Trains will be cancelled in full or be diverted not to call at Bradford Interchange. Some trains will start / terminate at alternative stations to normal. Disruption is expected until the end of the day.
Leeds to Manchester Victoria - The 12 minutes past the hour service departing Leeds will be cancelled. The 42 minutes past the hour service departing Leeds will be diverted, not calling at Bramley, New Pudsey, Bradford Interchange and Low Moor.
Manchester Victoria to Leeds - The 54 or 58 minutes past the hour service from Manchester Victoria will be cancelled. The 17 or 19 minutes past the hour service from Manchester Victoria will be diverted, not calling at Low Moor, Bradford Interchange, New Pudsey and Bramley.
Between York and Blackpool North - These services will be diverted where possible, not calling at New Pudsey, Bradford Interchange and Halifax. If unable to divert they will be cancelled.
Customers where possible can travel on the Blackburn to Manchester Victoria service and change at Todmorden for a diverted service to Leeds or travel to Manchester from Preston then change to a TransPennine Express service to Leeds.
Between Halifax and Hull - These services will run between Leeds and Hull, (cancelled between Halifax and Leeds), not calling at Halifax, Bradford Interchange, New Pudsey and Bramley.
Between Huddersfield and Bradford Interchange - These services will operate between Huddersfield and Halifax.
Alternative travel options:
You may use your ticket on TransPennine Express services between Manchester and Leeds.
Customers travelling between Bradford and Leeds are advised to use Bradford Forster Square station, as this route is not affected.
Limited road transport is operating between Halifax and Leeds calling at all stations.
