East-West Rail (EWR): What stock might be used once the line is open between Oxford and Bletchley?
Philip
27 May 2007
Manchester
How many 196s will EWR/Chiltern/WMT be using once the line is open between Oxford and Bletchley?
12LDA28C
14 Oct 2022
The back of beyond
I read some time ago that initially six of WMT's 2-car Class 196 units will be used to provide EWR services until EWR's own fleet of around a dozen 3-car units is built.
Is it confirmed that 196s will be used?
That was certainly the original plan, I've not heard that it has changed.
Brubulus
13 Oct 2022
Cambridge
Do WMT have enough for that... the 175s would work quite well for the route...
165s are too slow for EWR. Chiltern should run the initial service and be given the 175 fleet.
I am not sure on speed - it is a 100mph line but little more than a country branch in practice. I do however agree that as the only major operator of DMUs in the area Chiltern should indeed operate it.
hwl
5 Feb 2012
Using 30+ year-old 75mph stock on a shiny brand new 100mph railway wouldn't be a great look...
especially as they wouldn't be able to meet timings needed for the proposed timetable...
Bristol
It'd be interesting to see what the paths were timed for when the analysis was done. I suspect 165s were used to prove the concept, although can't prove it directly.
Doctor Fegg
9 Nov 2010
Charlbury
How will that fit in with Chiltern's 2 TPH from Oxford to Marylebone? There would have to be some creative timetabling / very brief turn round times to fit all those trains in the bays, along with the various GWR movements that also use the bays.
It's not an immediate prospect, but a Full Business Case study is about to be commissioned for the Cowley branch line, and the intention appears to be that it'll be served by the Chiltern services running through Oxford station. So it's plausible that the bays might be freed up in the next few years anyway.
The timetable won't work unless they are 100mph units.
A random 100mph unit would have been used in the modelling. It certainly wasn't a 165.
Jammy Dodger
20 Dec 2022
Essex/Kent
mods note - two threads merged at this point.
Created as a spin-off to discuss/speculate about potential operators and rolling stock for EWR.
CyrusWuff
20 May 2013
Not much to discuss in the way of rolling stock. The current plan is for six Class 196/0s (2-car units) to be sub-leased from WMT initially.
The reason why I think Chiltern is a sensible initial operator is that they have a DMU depot nearby (very easily accessible as long as Aylesbury is connected back on, even if not to passenger standards and with no passenger service, but still not hard to access via Oxford and Risborough) and they operate a large fleet of DMUs. They could well decide to outstation staff and a few DMUs at Bletchley, of course, that's up to them if it's more convenient to do so.
WMT may have DMUs but the maintenance depots are a long way away from Bletchley, which has historically caused a lot of unreliability on the Marston Vale, which really isn't acceptable for higher priority EWR.
What DMUs they might or might not use is relatively moot here.
I keep hearing in various places that that is by no means confirmed and may not happen. Plus even if it does it doesn't confirm that WMT will operate them; they could be based at Bletchley or even Aylesbury and just sent to Tyseley for heavy maintenance.
12LDA28C
14 Oct 2022
The back of beyond
No need for speculation. Pretty sure the decision would have been made already, as route learning etc will need to commence in little over a year's time.
If the quote about sub-leasing from WMT (or LNR) is correct, clearly WMT will not be operating them.
Jammy Dodger
20 Dec 2022
Essex/Kent
I assume that would be for Oxford - Bedford services, with frequencies at 1tph at most? Once Bedford - Cambridge services are started, along with an increase to 2tph Oxford - Cambridge (and any other intermediary services), more stock will be needed.
My guess (long-term) would be to use 4-car FLIRT's (755's?), or a bi-mode Aventra. If it was all electrified, the dormant 379's could be used (with some light refurbishment)...
I think the initial service is 2tph MKC-Oxford, which would require two pairs of units, one unit spare for emergencies and the other maintenance? I don't think the initial service is going to go to Bedford.
Long term I think it will be operated by Chiltern using whatever they're using, including it being electrified as part of that.
Jammy Dodger
20 Dec 2022
Essex/Kent
IMO Cross-Country makes more sense (especially given their experience with 170's between Stansted and Birmingham) in the longer term, given that it is a cross-country type route, and Cambridge is rather far away from the Chilterns...
Andyjs247
1 Jan 2011
North Oxfordshire
I would love to see 755s operating on this service. They are excellent trains although neither Chiltern or WMT operate them.
If the train service between is due to start in early 2025, when does the train operator need to have stock in place to train staff?
Jammy Dodger
20 Dec 2022
Essex/Kent
Would be decent options, the interior is the same as an intercity (745's), they are fast and quiet due to the power-pack design. Downsides are (like all UK FLIRT's) are the width and floor height (should be designed to the standard 1100mm, even if it gives level boarding at some stations)
End of this year, I'd assume. Crew training will take 6-9 months (main limitation is drivers). I don't even think all of the 196's have been delivered to WMR yet, and would likely be needed until the 730's arrive (whenever that will be)
Trainbike46
18 Sep 2021
belfast
The FLIRT floor height is designed to match the UK standard platform height, that really isn't a disadvantage, it is a key advantage of them, level boarding is game changing, and all new trains really should require matching the standard platform height for level boarding, as well as gap fillers like on the FLIRT
It's a regional service, not a long distance one; I'm not convinced about adding more services to XC like the Class 170 services they already have which are a very bad fit and could do with being taken off them.
12LDA28C
14 Oct 2022
The back of beyond
Except that CrossCountry do not currently operate any trains over any part of the route, and Chiltern already run trains over the Western section of EWR between Oxford and Bicester.
Passenger trains from December 2024 timetable isn't it? With testing from Spring 2024.
