Obviously I am referring to normal times, not the current situation.
Do bus companies still take action over fare evasion where you live? From what I can gather in my old stamping ground ( Newcastle) companies have basically given up and put everything on to the driver, in the unlikely event of seeing an inspector they invariably are there to check on the driver, not the passengers.
Your thoughts?
Been a long time since I had an inspector out and about. What has really happened has been the march of technology.
Passengers fiddling the system - there is still the ability to potentially over-ride i.e. pay from A to B but get off at C. However, the leaps of ticket technology in terms of m-tickets and the like have managed to massively reduce some of the larger scale fraud that used to exist. There were other scams like counterfeit passes, but 3D bar coding (QR codes) have also reduced that. Note that in some areas (like Merseyside) that there is a major problem with age related fraud on its MyTicket scheme where no ID is required for a person claiming to be under 19. Of course, in certain areas, we now have "tap and cap" with the need to tap in and tap out so that will also have an impact on fare evasion as more firms adopt it.
Managing drivers - the number of drivers fiddling the system was always a very, very small percentage of drivers; you could probably recall the few that got caught in your days and when they were, I expect you weren't that surprised. Sadly, you will occasionally get the odd one. With fewer cash sales, the likelihood is much smaller anyway nowadays, with ENCTS passes forming a major part of the travelling public, and also in respect of other m-tickets etc. The other issue was making sure that drivers were not running early or off route. With GPS, that is very easy to manage. Also, the amount of data that comes from the ticket machine allows you to undertake trend analysis much more easily so if there is a "wrong un", they can be identified relatively easily and steps taken.
Yes, there will be some fare evasion but to a level where the cost of resources to stop it means it probably isn't cost effective.
