Bromley boy
- Joined
- 18 Jun 2015
- Messages
- 4,609
But costs have been the limiting factor thus far. Done a few lessons but can’t afford to keep up anything meaningful at the moment. I must say I didn’t appreciate the difference in running costs between a “spam can” and a cirrus though!
(Apologies in advance for the length, I rather like talking about this subject
The cost of getting a PPL is undoubtedly high (although can be reduced by getting an NPPL, microlight PPL etc.)
Once you have that maintaining it isn’t that expensive, and people generally find that time and lack of currency are limiting factors. Flying is a very perishable skill: if you aren’t current you won’t fancy that sporting crosswind, or worse vis than you expected, so you’re more likely to throw it away, leading to a vicious circle of the less you do, the less you will be inclined to do.
This can lead to the repeated frustration of blocking a day out to go flying, booking an aircraft, planning a trip, driving to the airfield (1hr away in my case) only to find the weather simply doesn’t improve as forecast and you end up having a coffee and going home. The far more stressful alternative (I’ve done more than once) is taking off and rapidly wishing you were back on the ground...
The old aviation adage it’s better to be down here wishing you were up there, than up there wishing you were down here is an accurate one!
In terms of touring it can be done, but U.K. weather makes long distance VFR daylight flying difficult during the winter months especially. It isn’t a reliable way to get from A to B (and back again) when you want to.
Serious touring in high performance aircraft is expensive - these things are enormously expensive to buy and use a lot of fuel - a Cirrus, for example, costs £400-700k to buy and uses 12 gallons of fuel + per hour. Therefore hiring one is never going to be cheap. It will cruise* at 160kts**+ but to really use that performance and to use flying as a means of getting from A to B reliably you would need an instrument rating (and to maintain IMC competence).
A 172 or PA28 costs a lot less to buy, fuel and maintain yet still has 4 seats and cruises at 100kts, which is quick enough for most purposes.
Overall it’s a great hobby but you always need to have an objective to aim for, whether that’s mastering mountain flying, an IMC rating (IR(R) as it’s now called), aerobatics, doing a commercial license or whatever. Boring holes in the sky and the “£200 burger run” you’ve done ten times before quickly becomes boring and expensive.
Yes that and the shifts I would imagine make time for any hobby I wondered how you manage to fit it in?
Not too much of an issue. The good side of shift work is you get a fair bit of time off
*Aircraft “cruise” at an airpseed (speed relative to the body of air they fly in), as opposed to groundspeed (which is speed over the ground, as per a car speedometer).
If the wind is 20kts, an aircraft cruising at 100kts airspeed will have a groundspeed of 80kts flying directly into wind, 120kts flying directly away from the wind - this makes a huge difference to how long a trip out or back can take (and therefore fuel burned).
**1 knot (nautical mile per hour) is 1.15 statute miles, in case anyone is wondering.
EDIT: I’ve asked the mods to split this into a pilots’ thread, in general discussion.
@Economist, @Emmsie, way @SPADTrap, @Dave1987, @H4R, @AlterEgo, are you with me? Feel free to contribute and we can see whether it takes off, or simply reaches “coffin corner”, stalls and crashes and burns.
Fly well, guys (and gals)
