telstarbox
I've seen some freight sidings in the tangle of lines around Battersea. What is the actual flow here? It looks like aggregates - are they brought in here then used on the various construction sites in London?
Ah, sounds like Stewart’s Lane. The aggregate terminal there receives regular trains from Cliffs (near my eponymous Junction). There are also trains staged via Acton, typically from the Mendip quarries, I believe.I've seen some freight sidings in the tangle of lines around Battersea. What is the actual flow here? It looks like aggregates - are they brought in here then used on the various construction sites in London?
That doesn’t actually help with the OP’s question about Battersea though?There is a days aggregate at Purley station as well normally see a freight unit around there most days
The Mendip services don't run every day to all destinations so the Purley and Stewarts Lane are alternative destinations on different daysThat doesn’t actually help with the OP’s question about Battersea though?
I take your general point but the OP did ask specifically about the actual flow in the freight sidings in the Battersea area, not the wider area or region...The Mendip services don't run every day to all destinations so the Purley and Stewarts Lane are alternative destinations on different days
