Am I correct in thinking they were only at present interviewing for the Kent positions hence people only been offered the Tilbury depot.If I’m wrong I’m sure I get corrected lol
Tilbury isn't in Kent, it's in Essex....
I agree with Tim, very good advise. Make sure you are well rested and keep calm. Tests are not particularly difficult however you do need to focus.
As Long as you stay calm and switched on you'll be fine.
All the best anyways.
Keep hydrated, make sure there are no distractions and good luck!Many thanks Ladellboy, I had the tests & practise tests through today so will get stuck into them, fingers crossed!
Cheers buddy
I’ve had the same emails but I’m positive they are for online tests?!?
The sjt isn't something you can practice really, you just need to be yourself and I agree some of the questions can be a bit tricky. I don't think it's an additional stage, it seems to have been moved as ours were on the same day as the mmi! Good luckThe initial email mentioned assessment days but these are two online test to be completed by Thursday, so not sure if this is an additional stage due to so many applicants or what? Been doing some practise and getting on ok, the SJT are difficult though as doesnt show you the solution or give you any clue how you’ve done so will practise that a little more on a website I found & lee my fingers crossed
How do you PM someone???? Maybe it's because I'm using a Surface Pro but there doesn't seem to be an option anywhere to message someone??!!
There is a minimum number of posts required to do this. I think it’s 5 but I could be wrongHow do you PM someone???? Maybe it's because I'm using a Surface Pro but there doesn't seem to be an option anywhere to message someone??!!
Is this for Freightliner? Good luckWell I applied, was quite surprised to immediately have to do the online tests as the first stage, rather than any sort of application form... and also it was almost the exact same test I did about 30 minutes ago for Crossrail
Though I did like the little "What do you know about us" type questions that they threw in there.
Well there we go, another application in...!
No I only applied for one but having seen others apply for two I’m now wondering if I should apply for the other one too...?!have you applied for the IM and the HH positions? just wondering if you need to do two lots of tests? I am also in for a shunt driver job with FL, I have some tests to do for them so got 3 lots of tests to do by the looks of it so hopefully get somewhere with one of them, I am pretty confident with the visual tests it's just the SJT that are a bit up in the air as the responses can be open to interpretation. Good luck all will be good to be part of a live application process with you guys rather than read back on past applications!
