Due to a points failure north of Haywards Heath station in the up direction, fewer trains can run.
Gatwick Express branded trains from Brighton to London Victoria are cancelled between Brighton and Gatwick Airport.
Some are showing as cancelled but earlier others are just not showing at all. When I looked up the 20:39 from Brighton on timetables.trainsplit.com it said Last schedule change 16/08/2023.
Surely if it wasn't showing on the live deapture board, there should be a more recent date for the scheduled change.
It's worth adding that earlier it had cancelled against Brighton and Haywards Heath but now it just shows cancelled against Brighton.
The web page can be found at https://timetables.trainsplit.com/times.aspx?uid=P15908&date=20240219.
It may all be working as intended and it is just that I do not understand how the timetable history works in terms of updates to it.
The first screenshot shows Brighton and Haywards Heath cancelled and the second screenshot shows just Brighton. The last scheduled change is 16/08/2023.
Currently, the journey planner shows no cancellation as can be seen in the screenshot below.
