Francis
The Greater Manchester Wayfarer ticket is great value at £12, or £6 concessionary (over 60's). It extends as far as Grindleford in the Peak district on the Manchester-Sheffield (Hope Valley) line.
Presumably, given the new conditions of carriage (below), combined with an off-peak day return Grindleford-Sheffield for £4.30 (£2.85 senior), this combination should now be valid on East Midlands or Transpennine fast trains Manchester - Sheffield, rather than just on the Northern Rail two-hourly service stopping all stations?
I can't see anything in the GMWayfarer conditions which would contradict this. Can anybody else?
The same would be true for fast trains to Crewe, with a Holmes Chapel - Crewe OPDR, for Liverpool with an Earlestown-Lime St OPDR, for Huddersfield or Leeds with an OPDR from Greenfield.
The removal of the requirement to stop at the last Wayfarer area station is a real game-changer.
14.1 Unless shown below, you may use a combination of two or more Tickets to make a journey provided that the train services you use call at the station(s) where you change from one Ticket to another.
14.2 If you are using a Season Ticket, daily Zonal Ticket, or another area based Ticket such as a concessionary pass, ranger or rover in conjunction with another Ticket and the last station at which one Ticket is valid and the first station that the other Ticket is valid are the same, then the train does not need to call at that station for your combination to be valid.
14.3 Some Tickets specifically exclude their use in conjunction with other Tickets. This will be made clear in the terms and conditions when buying such
Tickets, and you cannot use such a Ticket in conjunction with another except as set out in 14.1 above.
