GWR Class 769 information. (Units no longer with GWR - Off Lease March 23)
Deepgreen
12 Jun 2013
Betchworth, Surrey
Saw it on my morning walk heading up to Redhill - couldn't hear the engines so may have been on third rail (expect not though as it is a long descent) and then again at Reigate on return
There is, at least, one rear light showing there! Is there a serious electrical issue here? Obviously, unreliable rear lights are a major safety problem.
Minstral25
10 Sep 2009
I think it is just because of the angle - on other photos I took it is not visible. Probably only visible if you are directly behind train.
skyhigh
14 Sep 2014
It's clearly just the way the camera has captured it. There's no way they'd be allowed out with 'unreliable rear lights'
FenMan
13 Oct 2011
A short video of the unit passing Blackwater northbound. Sorry about the thumb!
XAM2175
8 Jun 2016
@skyhigh has it: digital cameras and LEDs are known for not playing well with each other. You'll see a similar thing in photos of LED destination displays, and sometimes in videos of trains with LED headlights that look like they're blinking.
northernbelle
10 Oct 2018
Today's test run. 769943 appeared to be running without tail-lights, at least on the outbound run, with both legs of the working seen here near Betchworth.
View attachment 98152View attachment 98153
Are you sure it isn't just a trick of the camera not having picked up the frequency of the LED lights? I notice in another photo that one light appears to be lit. It's a common issue with Class 68 photographs and destination displays on the front of buses as well!
Minstral25
10 Sep 2009
This video
Sounds like its on the DC 3rd rail
That of the motors are very quiet!
As it passed me in the cutting towards Redhill it did sound very quiet from the motors that I suspected it on third rail too, but lack of any flashes suggests that it could be the engines are quiet. Would be interesting to know. I did a short Video as well but don't have an online account to post here.
It did stand outside Reigate for a long time as there was a Southern unit in the platform (see pic), which would have enabled time to fire up engines which were audible as it passed under the Footbridge at Reigate.
Bob Price
8 Aug 2019
I have seen them on non electrified rails on the Valley Lines and the diesels on those are very distinct. Have a look at my YouTube video of one leaving Aber to see what I mean.
Deepgreen
12 Jun 2013
Betchworth, Surrey
Surely that would’ve been due to the harsh sunlight? I’ve found the newer-style LEDs make it harder to see.
Certainly nothing to do with sunlight regarding tail lights (not like with destination displays) - if so, the railway's in big trouble! No, it seems that, at fast shutter speeds, some LEDs do seem to flicker and can appear to be 'out'.
I would hope not (and it seems to be a quirk of LEDs and fast shutter speeds), but errors can, and do, occur in any system. It makes me wonder, do modern control systems have indicators for failed lights? Would the driver visually check the rear before leaving the depot?
fgwrich
15 Apr 2009
Between Edinburgh and Exeter
Nothing to worry about - These use the latest type of LED marker light, which pulse much faster than the human eye or many camera's can catch. Indeed you will get the same result if you try and photograph a Turbo or 68 / 88.
Wednesday's trips look like they are having a go at working in actual Reading to Gatwick timings (albeit with a stop at Ash instead of North Camp).
I guess the interesting thing is how it performs against the 769 schedules with the slightly slower running times relative to the Turbo timings that applied between 1995 and 2018.
aleggatta
28 Sep 2015
Anyone know if a retractable version of shoegear has been fitted or just appropriate ramps to the third rail that might have been missing on the appropriate junctions?
big all
23 Sep 2018
redhill
Shoes must always be retracted otherwise all shoes are live by default on the unit even if only one is in touch with the juice rail
all dual mode traction as part off change from one to the other involves full isolation from the other mode/s to operate??
you can often check [shoe down button on a 73]if powers available to swap to but you never run with more than one mode directly connected with "changeover" isolating from then connecting too to avoid danger off cross feed ??
JN114
28 Jun 2005
769s retain the fixed shoegear of their donor 319s.
I believe all areas that may have needed ramps have been checked for ramps and those needed installed.
skyhigh
14 Sep 2014
Modern trains do have indicators for failed lamps. Some older stock (such as 158s) have mimic panels inside the cab which also indicate if a lamp is failed, but I don't sign 769s so I don't know if they're fitted. The crew also check the head/tail lights are illuminated prior to departure and when changing ends. In addition, a train is able to proceed at linespeed with only a single tail lamp lit. To be honest, failed lamps aren't really a massive problem.
big all
23 Sep 2018
redhill
on a 319 they are not actually fixed they raise rather than fully retract like a 73 but well clear off the electric rail
AM9
13 May 2014
St Albans
Rules aside, an EMU that has lost one or more of it's cars is unlikely to go unnoticed by it's driver, or any bystander. :)
aleggatta
28 Sep 2015
I mean, even the 700s have fixed shoe gear (this caused some of the ‘lost shoes’ incidents on the GN side when they first started visiting there.) As part of training you are taught to always consider shoe gear live, even if you know it is fully isolated. The traction changeover system will be set up to not allow parallel feeds on the units, so to that end even with fixed shoegear they will only become live in a platform with third rail present? The reason for my question was more as I don’t believe a design of retractable shoegear exists for this bogie design etc, but this has been answered now.
JN114
28 Jun 2005
There’s vertical “play” yes, to allow for bumps etc. but there is no mechanical means of retracting them at all, the traincrew would have to go lineside and manually tie them up if they needed to be actually raised. Any isolation as you put it, at least on the EMUs I’ve dealt with (387s and 769s) is all handled within the train - although to a 769, Diesel and DC mode are the same, and the diesel generators are tied directly into the shoe bus, they’re just a 319 with Diesel engines that pretend to be the 3rd rail.
Senna1210
30 May 2019
769 shoe gear is fixed its as was on the 319 its not posible to raise it
the 769 gwr units have a mimic panel inside on the header panel for the headlights/tailights so the driver can see what is on
Nicholas Lewis
9 Aug 2019
The shoegear has been moved to the inner bogie though - layouts are generally setup with gaps positioned to avoid a 4 car gapping
big all
23 Sep 2018
redhill
its is 30 years since i trained on 319 so perhaps false memories sorry if i am wrong and have misled ??
we got them on the southern when the first class 319 allowed the cascade to southern suburban servivces ??
According to RTT it looks like there may be two units heading to Gatwick today
https://www.realtimetrains.co.uk/service/gb-nr:K06066/2021-06-16/detailed
Isn't it the same one? There are two trips but the turnaround time at Reading enables then to be the same one.
